Help compressor issues
  • peterairfix
    • Jul 2012
    • 11139
    I just given my compressor a service worked fine before and now I have reassemble it it no longer fills with air I have looked at you tube videos but I can't see were I have gone wrong I have a weak delivery of air at the airbrush but that's all it's been running for five minutes but still nothing hellllpppp!!!
  • Nicko
    • Apr 2019
    • 1637
    • Nick
    • East Anglia
    Stuck blow-off valve?
    Nick
    • AlanG
      • 6296
      You did put the water drain plug back in the bottom? lol
      • adt70hk
        • Sep 2019
        • 10540
        Not saying a word!!!
        • peterairfix
          • Jul 2012
          • 11139
          Nick
          No never been touched
          Yes it just not filling the tank all I get is a trickle of air at the brush end and nothing else.
          • AlanG
            • 6296
            You getting a trickle coming out of the tank before the pipe? What items in this 'service'did you remove/refit? Is there a chance you've put one in back to front. Dos the compressor 'sound normal' when running?
            • peterairfix
              • Jul 2012
              • 11139
              I just took the cylinder head off and cleaned the moisture and drained the tank of water and nothing else the piece of metal that is on the cylinder is it meant the flat against the hole?
              • AlanG
                • 6296
                There wasn't a gasket/seal between the cylinder head and tank?
                  • 16165
                  The brass coloured thin piece of metal which is held in place with a screw needs to lay flat and central over the hole at the other end. If it is slightly curved turn it over.
                  I think :smiling:
                  • peterairfix
                    • Jul 2012
                    • 11139
                    Sorted it just took a bit longer as the tank was completely empty all up to pressure and working.
                    • Steven000
                      • Aug 2018
                      • 2891
                      • Steven
                      • Belgium
                      Good to hear :thumb2:
                        • 16165
                        Worry over - good. Happy airbrushing.
                        • peterairfix
                          • Jul 2012
                          • 11139
                          I was beginning to panic.
                          • peterairfix
                            • Jul 2012
                            • 11139
                            Mind you the air tank was half full with brown water no wonder It takes twice as long to fill up.
                              I'm sure you know the moral of this story by now Peter, but drain the tank daily if at all possible.
                              Mine is starting to make a weird noise, it used to be super quiet, so I think it's time to take the head off again and have a look-see.
