Hi all,
I wondered if anyone had similar issues to mine with Ammo One Shot primer.
The issue being regular clogging of my airbrush. Half way through a priming of a model, the paint stops coming out every so often then not at all. There seems to always be some tip dry right on the end of the needle when breaking down AB to clean. There was also some clogged in the nozzle one time. I’ve played around with psi’s and thinning ratios and adding flow improver, where I’ve felt comfortable laying on the paint but every situation it always the same.
Is it just the paint? Is it worth trying something like a new needle? Or is it putting it down to not getting on with it and trying a different primer? It’s had a new nozzle. It’s a shame as when it goes on correctly it gives a solid finish.
I’m using a Sparmax max-4 (0.4mm)
