Ammo One Shot Primer issues
I agree Dave , thought Rick had been at the bourbon again, or the thinners .Comment
Matt I had problems with tip drying, didn't want to use solvent paint as don't want to have to wear a mask anymore as had to at work when spraying cellulose.
I had problem after problem, tried different combinations of mixes, even bought another ab. In the end started to use 3 rd Gen AK paints and bought a Neo ab .
Since then I've had no problems, it had got to the point where I dreaded the thought of using the ab.Comment
Mine is an absolute dream to operate and it never lets me down. Bought it back in the early 90's.....dual action .....siphon feed. Of course I use those "smelly" non environmental friendly solvent based paints that are slowly being legislated out of existence.....but they get the job done even if I have to look like Darth Vader in the process........."Luke, I'm your father"....etc. Rick H.Comment
WELL i think all you guys with A/B have the patience of a saint to put up with usein them as a freind let me borrow his an yes i dont know zilich about A/B 's as i have not used one before but he mixed the paint in the A/B jar an i treid to use it an it was not very good an kept stoppin sprayin an the compressor kept cuttin in an no spray at all an yes i know i make a lot bigger models than what you guys make but for me id rather use the ole rattle cans as ive hardley ever had any trouble with them its just point an spray but yes i understand with a A/B you can spray very small areas an they are very good for that so all you guys have fun usein them but they are not for me but this is just my opinion an im not tryin to upset anyone so have fun with them
chrisComment
Funnily enough, my issue with acrylic primers isn't spraying them, it’s sanding them if any remedial work needs to be done. I’ve switched to them for my figures, but will still use cellulose primers for tanks, aircraft, etc…..
Acrylic primer (or paint) and isopropyl alcohol is a bit of a no-no though. It tends to turn the paint from a solution into a colloid gel (think gunk).
I always start an acrylic spraying session by running at least one load of water through the brush and spraying until the brush is completely dry….this removes residual cleaning agent and minimises my spraying issues.Comment
