Best material for base board on a diorama?
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
With an upcoming diorama for the PBI GB, I will need a decent base upon which to build.
What materials do people use?
For the couple of small diorama's that I've built so far, I have just used plain foam type board, eg: 5mm Polyester type A4 boards.
They were ok, but I am slightly concerned that my next diorama will be a bit bigger, approx 450mm by 250-300mm, ish....
Foam board is ok, but its a bit light and slightly flexible, I suppose I could double it up and stagger the joints maybe?
Anyway, open to ideas and suggestions on what others use as a base for diorama's.
I use MDF, old picture frames or else anything else that seems appropriate! (PS reference a later post that I've just replied to - don't even think of leaving - I wanna see your PBI production!)
PM me if there's something you would like to talk/rant over mate!)
Thanx for the offer, 8-) but not me leaving mate, its someone else, but sad to see if they do go....
Fibre board......i just bought an A2 size 5mm thick....less than a fiver from hobbycraft.....going to cut it into 3 stick together to make 15mm thick.......by time ive added some filler im hoping its going to quite sturdy
I have ysed sheet polystyrene in the past
How big do you need?
My Dio will be about 450 x 250 ish, I have some of the A4 foam boards (5mm thick), but one won't be enough, so may need to stick some together?
Have also looked at hardboard, and MDF, and maybe even some solid insulation type board?
MDF is good, just be careful in the preparation mste
Just coming back to this thread again. My last diorama (commando car in forest ammo/ re-supply dump), I found that the base (5mm foam board) warped, and its also warped on another one, my old PBI dio. I still have lots of foam board, so don't want to just throw it away.
Would adding another layer under the foam board stop it warping, eg: I'm think of sticking it with pva to maybe some thin balsa wood sheets, or thick type cardboard or something similar?
Peter,
I use off the shelf picture frames for most of my bases. After removing the glass I use the hardboard sheet in the frame and stick the foam board to this, one it stops the warping and you get an exact fit in the frame.
I use aged (bin rescued) shelf material, plywood (hardwood frame for stability),or Masonite (hard pressed paper & glue) w/wood frame for base and foam board (paper both sides w/foam in middle) or foam packing material for topography, glued w/PVA and smoothed where needed w/taping compound. Used these for decades w/no warping.
I used foam board professionally for many years. Make a shallow tray(25mm deep?) and diagonally cross brace it . If necessary use small triangles to keep the sides at 90degrees.Then turn it upside down, job done, model base. If you want you can enclose the bottom as well. 10mm foamboard is better, but it should work with 5mm for smaller bases. Use uhu glue rather than PVA because of the moisture content.
Cheers, think I may have some hardboard (possibly 8mm) in the garage, so may investigate that option, its only going to be a small dio base, not too large.
I have found that if you glue a sheet of thick paper to the underside it minimises warping. The terrain on the top can shrink and warp the board. The paper underneath also shrinks and counteracts that warp.
5mm is only really suitable for very small bases.
What's P B I GB ?
6mm MDF works fine for me. I get my local hardware store to cut an 8ftx4ft sheet into rectangles 2ftx2ft, 2ftx1ft. I get four of each and I get two of each 3ftx1ft and 1ftx1ft .
As above @MADTONY PBI = Poor Bloody Infantry and GB = Group Build, where people agree to all do a build (separate builds, not one build together) on a particular subject. So in the case above it a was a group build on anything to do with Infantry troops. Very enjoyable it was too, although my base did still warp a bit! 🤷‍♀️😥
I made lot's of dio's with 6 and 12mm MDF without problems - but most materials start to warp if only one side has another material stuck to it; like plaster on one side of a foam board. Even MDF can warp a lot when painted or glued one side. I once glued a puzzle with wood-glue on a large 6mm MDF panel, the glue shrank when cured and warped the whole panel. But for small dio's (like your 450mm) MDF or foam glued to a panel should work fine. Goodluck
Thanx for the info, but its an old thread thats had some recent comments, my original Dio mentioned in the OP was built months ago. Still useful info though, so cheers. I tend to glue the foam board to either a balsa base or a ply base now, seems to stop most of the warping.
I always seal unfinished wood products with clear varnish and paint to be finished surfaces before adding foam, plaster, or glue for dio. additions. Some bases are close to 30 years old w/o the least bit of warp. The larger ones have hardwood subframes.
