- Joined
- Dec 28, 2023
- Messages
- 2,809
- Location
- Swale Kent UK
- First Name
- Peter
With an upcoming diorama for the PBI GB, I will need a decent base upon which to build.
What materials do people use?
For the couple of small diorama's that I've built so far, I have just used plain foam type board, eg: 5mm Polyester type A4 boards.
They were ok, but I am slightly concerned that my next diorama will be a bit bigger, approx 450mm by 250-300mm, ish....
Foam board is ok, but its a bit light and slightly flexible, I suppose I could double it up and stagger the joints maybe?
Anyway, open to ideas and suggestions on what others use as a base for diorama's.
