No problemI can't help I'm afraid but very interested in the replies.
OK, thank you so much for the reply. Will look into them. Thank you.I use the Elegoo Mars 2 , which I bought in 2022 and I'm still very happy with it. There are several newer versions by now and it also has a big brother called Saturn, so depending on how big the models are that you want to print, you could do a lot worse.
Impressive!Are you looking at resin or fdm printers? I have one of each. An old Ender3 which is an fdm printer. A plastic "wire" is fed through a very hot nozzle to extrude liquid plastic at 0.4 mm dia. It then draws your design in 3D. The prints are very strong but the detail is a bit weak. I also have an AnyCubic mono 4K resin printer (also over 3 years old) that uses a tray of resin with a mono lcd screen underneath. The screen displays your image in individual layers fractions of a mm thick. Very high resolution, but the prints can warp if not printed correctly. The prints aren't as strong as fdm. Resin printers can also be very smelly! Fdm printers are virtually smell free. I have used both printers to produce my model of my Austin 7 car. I would never have been able to make the model without them, but I had to teach myself cad first.
Lee
Thank you so much for that infoAre you looking at resin or fdm printers? I have one of each. An old Ender3 which is an fdm printer. A plastic "wire" is fed through a very hot nozzle to extrude liquid plastic at 0.4 mm dia. It then draws your design in 3D. The prints are very strong but the detail is a bit weak. I also have an AnyCubic mono 4K resin printer (also over 3 years old) that uses a tray of resin with a mono lcd screen underneath. The screen displays your image in individual layers fractions of a mm thick. Very high resolution, but the prints can warp if not printed correctly. The prints aren't as strong as fdm. Resin printers can also be very smelly! Fdm printers are virtually smell free. I have used both printers to produce my model of my Austin 7 car. I would never have been able to make the model without them, but I had to teach myself cad first.
Lee
Thank you. I will have a look at those. Initially, from what I can tell, I need something that doesn't take up too much space and is ideally under £100!!Maybe try here? see linky:
3D printing forum
Or here....
UK workshops 3d printers
Or here....
Model Eng forum 3d Printing
Or here....
FaceAche 3d printing forum
I can only see a sub-£100 printer bringing you heartache and pain.Thank you. I will have a look at those. Initially, from what I can tell, I need something that doesn't take up too much space and is ideally under £100!!
3D printing forum
Or here....
Or here....
Or here....
.........OK, point taken. Thank you for letting me know. Appreciate your timeI can only see a sub-£100 printer bringing you heartache and pain.
I have a fdm and a resin printer , which i have had sitting doing nothing for a long time due to a new eyesight problem.
FDM are great for less detailed items , resin for more highly detailed , but they both have a large learning curve.
I agree, IMHO you tend to get what you pay for, and for that you won't get a lot!I can only see a sub-£100 printer bringing you heartache and pain.
It would be a cheap way to learn the ropes if it works properly.I agree, IMHO you tend to get what you pay for, and for that you won't get a lot!
But I suppose it could be a good (cheap) way to get to learn the basics?
