AFV Club, Tiger I, Panzerkampfwagen VI, 1:48
pjgtech
Peter in Kent UK
Swale Kent UK
Peter
I am now on a quest to build many different sized Tigers.....I have already built a 1:144 scale mini tiger, and one of the first kits I built when I got back into the hobby was a little Airfix Tiger in 1:72, so this is the next scale up, a nice 1:48 scale by AFV Club. Then after this one I have a 1:35 in the stash, so will have a whole set of four, all in differnt sizes! Lol....
Box and sprues, NB: I actually already started this one a couple of days ago whilst fiddling around with my Lynx Chopper build.
AFV Tiger 1_48 scale  (2) (Large).webpAFV Tiger 1_48 scale  (3) (Large).webpTiger 1_48 AFV orig pics apr26  (1) (Large).webpTiger 1_48 AFV orig pics apr26  (2) (Large).webpTiger 1_48 AFV orig pics apr26  (3) (Large).webpTiger 1_48 AFV orig pics apr26  (4) (Large).webpTiger 1_48 AFV orig pics apr26  (5) (Large).webpTiger 1_48 AFV orig pics apr26  (6) (Large).webpTiger 1_48 AFV orig pics apr26  (7) (Large).webp
This will be in desert sand yellow paint job, just like the other ones, as I want them all to look alike.
The kit appears to be nicely detailed and has only a few PE parts, mainly grills, and the horrid rubber tracks, although I've done a few now and I just superglue them together and put a weight on them and leave for few hours and they seem to set ok with a nice strong bond, so you have a bit of stretch, if needed when getting them on the wheels.
Started with the main body/chassis, good fit, no drama, no large gaps.
Then put the turret together, again, no drama, everything fitting as it should.
NB: I've done a couple of AFV builds now and they have all been good IMHO.
Then I gave the chassis and turret a coat of grey primer (Ammo One Shot).
Then decided to prime the parts on the sprue, I find this a bit easier, especially for the small parts, rather than painting them in situ trying to get into awkward little spaces, etc.
Then the rear bits went on, exhaust manifolds, etc. Then added the PE grills to the rear.
Made a bit of progress, the main chassis and turret build is mostly done now, just need to add the wheels and tracks and some pioneer tools, etc to add.
Rear exhaust added (2nd pipes) and little gap filled.
Started the first top coat sand/dark yellow.... as with all brush painting, first coat always looks gash!
Little bits added, eg: front lights, spare track, chain couplings/links, machine gun barrel, etc.
Lots of bits added to the rear too, eg: rear chain couplings/links, baffles, engine cover handles, little side smoke/mortar thingies?
Turret pretty much finished too, side smoke/mortar thingies, hatch covers and handles, access covers, etc.
another view of the rear.....quite a detailed little kit TBH....
Wheels painted up and tyres/rubber sections.....
Whole body/turret now covered with first top coat, patchy, etc, so will need at least another two coats, second coat smooths things out and gets rid of most of the patchiness, third coat tends to give the final finish.
Then we will be adding the wheels, etc .....
Oh B*gger, just noticed I've put the rear exhaust baffles on upside down!!! will need to turn them round....
Not done much today, other things on, etc...
But did manage to sort out the rear exhaust baffles, they were well attached, so rather than also remove the actual exhaust pipes, I cut the join and levered off the baffles. Cleaned them up, the re-attached but now the correct way round!
Will need tidying up, with a bit of gap filler and paint touch up, but it was bugging me, so had to be done, Lol.
Have now also started on the wheels, one side is now fully attached, apart from the last drive drive/guide wheel.
AFV have used tiny, (and I do mean tiny!) little screws to secure alternate wheel sets in place.
I had to resort to my smallest electrical screwdriver, as its the only one small enough to fit the tiny screw heads!
I'm making sure I have really good secure connections for the wheels, as the horrid little rubber tracks will need to be stretched over the wheels as it looks like they will be a relatively tight fit, so don't want to have loose wheels at that point!
Please note the gun/mantlet assy. is upside down in the turret.
Bit more progress, gaps filled around exhaust baffles (after they were cut and turned round the right way, Doh!)
All wheels now on. Did a bit of dry brushing on the exhausts to give a rusty look.
Rear exhaust / baffle covers now on.
Gotta think about putting the tracks on, probably tomorrow after wheels have fully set, etc.
Tiger I 1_48 pics5 apr26  (1).webpTiger I 1_48 pics5 apr26  (2).webpTiger I 1_48 pics5 apr26  (3).webp
Well, there you go, as advised above, by @minitnkr I did indeed put the bloody turret mantlet on the wrong way round [Doh!]
I'm sure I double checked it as well, but I did not look at the box art which clearly shows the correct way round. I think the instructions have a couple of illustrations where its not quite clear which way round it should go, thats my excuse and I'm sticking to it.... Lol.
So it is now fixed.
I tend to just glue everything in place, don't really go for moveable parts, so the barrel/mantlet was originally glued in place.
The mantlet has two side pins holding everything in alignment/place, these had been glued too.
Therefore I had to drill those out, actually I used my (new) Dspiae grinder, but with a very thin grinding tip, and it did the job well. With some gentle persuasion I got it out without destroying the turret.
Bit of sanding down, flipped it round and its now on correctly, I have added some new side pins, out of old thin sprue. They will need cutting/sanding down when they have set and then the paint will need retouching, but thats it.
Thanx for the heads up, I'm sure if nobody had said anything I would never have noticed, Lol!
You're welcome, my eye was drawn to the monocular gun sight aperture, an early improvement, and noticed it was on the wrong side.
AFV Club kits are usually pretty good. They do like a lot of very small parts but that makes for nice detail. 1/48 is a nice scale. Apart from a couple of errors, easily sorted, it looks like great progress. Only the big one after this.
Tracks are now on, always a little sigh of relief when it's those horrid rubber things!
Have also now added the nicely detailed towing cables and pioneer tools.
I've got a reasonable technique for these tracks now. I always CA them, don't use TET, don't use Revell adhesive, don't heat them up and melt them, CA does the job.
Once CA is applied I try to add bit of weight around the join to get a good connection and then leave them.
I also make sure the wheels have a very good connection, especially the end/drive wheels where the tracks will be putting most pressure if they are a bit tight.
Just prior to fitting them I sort of pre stretch them, eg: give them a few little tugs in several places, as they do have a bit of stretch.
Then carefully, stretch them over the two end wheels, trying not to distrub the wheels as much as possible.
Here's a dry fit of the main body/chassis and turret, but not finished yet.
Next up will be the track side covers, then a little bit of stowage, but not much, most photos I see of Tigers they seem to have very little stowage on board, unlike say Sherman's which always seem to be fully loaded up to the max with everything, and the kitchen sink!
Then we are on to a gloss coat, then decals, then some light weathering, so we are getting there.....
That's looking good. You've cracked the rubber track malarkey.
This mornings little update....
Gloss coated last night, so its had a good few hours to harden....Ready for decals....
I left off the left hand side towing chain/rope/cable, which normally is secured above the side track plate, as one of the decals needs to go under the chain.
Decals went on well, no issues.
I then added some small blocks onto the top of the tracks and CA'd the the tracks to get a little bit of "track slack", this is how they ended up, not too bad IMHO.
I have also now added the side towing chain/rope/cable to the side track plate.
Then I added a light panel wash, a light fuel wash, and a light grime wash. I think I have a tendency to overdue the weathering, so I'm trying to restrain myself a bit more and not go overboard.
I also added a light dry brushing of flat aluminium to pioneer tools and track links, etc.
Think I may add a light rust wash and some very light chipping and maybe a chain to the front links.
Then it will be a final matt gloss coat and we should be done, maybe later today...
Calling this one as now done. ;) (y)
Few final pics then I will put up a Completed thread....
Came out quite nice, I really tried not to overdo the weathering this time, still not great, but every model I'm getting a little bit better.
Slowly learning that less is more, etc.... :)
Last things I did was to add a chain to the front towing linkages, and a couple of straps to the stowed items, add a final light rust wash and a final light grime wash, and then a few hours later, a final matt gloss coat.
Here she is....
TigerI 1_48 AFV final pics fone (5).webpTigerI 1_48 AFV final pics fone (6).webpTigerI 1_48 AFV final pics fone (7).webpTigerI 1_48 AFV final pics fone (8).webp
