1/35 TAMIYA StuG 1V
Coming along very nicely John. Very nicely detailed.
Looking good John. Paint will bring it to life nicely. Agree with Joe ref fillers. Acrylic fillers work well for cracks and seams, but laquer fillers, like Tamiya, are best for dents and divots. They bind into the plastic and sand to a feather edge.
Looking mighty fine John!!
Thanks all.
Yes that acrylic filler is ok for those mentioned, I've just cut and wired a head, and used Tamiya to start the filling.
As mentioned about, the figure I want to look at the side, while speaking to some ground soldiers. Not wanting to fit a new head, I've cut and wired this one. Using Tamiya filler , will need to add more but applying in layers.
Mean while the rest of the parts, minus the tracks, have had a coat of primer. Used Ultimate own brand, found it to be perfect as no thinning required.
Have done those tools this way off the kit as I will fully paint and put them on later. Next will be the main colour and chipping, looking forward to that part.
John.
Afternoon all.
Yesterday I started the base.Using XPS foam 40 mm thick . The Proton was used, but as the length is limited, you have to join to get to the required size. Those marks are from the tape when the PVA stuck to the tape .
As it will be covered, there is no problem.
PVA on the XPX FOAM, brush marks show the direction of the adhesive, on the corresponding top section, the glue goes the opposite way .
Leaving it for 5 mins to become tacky adds to the grip. I still move the two sections in opposite directions to expel any air and increase the even coating. The top is Kappa Line foam board, by far the best out there.
Nice and thick base, helps make to make it stable.
Now weighted and left to dry overnight.
The pins in the triangle setting help to hold the top in place while you place the weights. Finally, I add the container to get an overall pressure.
Done a base plan, to help with where I want to build.
That's it, not exciting to some I know, but to any of our diorama builders it might be.:)
John.
