- Joined
- Mar 4, 2004
- Messages
- 4,823
I'm having to do it manually, and only use the lines we stock, that's why it will take me quite a while to do, it will also depend what the name of the paint is, if I have RLM02 then it's easy to find, but blue grey or blue gray, not so easyWhere are you pulling the info from?
I want to make it easy for people, if they search for a Tamiya paint and that’s out of stock, on the product page there will be the other alternatives with a add to cart button, just makes it quicker, it would also serve as a, “I didn’t know that brand did that”how about just one downloadable spreadsheet or PDF,
It’s not to convert colours, its the product page, it’s a quick reference if the one you’re looking at is out of stock, but it also shows other brands of the same colour.good idea mate, but I use a free app called Hobby color converter. That gives you alternatives from lots of manufacturers and has a scale converter as well. I would thoroughly recommend it
No they will differ, but what the manufacturer calls them will be the same.Dark green from tamiya won't be the same as dark green from humbrol or Mr hobby or Vallejo.
As I’ve said it’s not a conversation chart, in this case, it’s all the other clear greens we stock. The way I thought it would work was, if someone searched for example C138 clear green and it was out of stock, you would see the alternative listed below, rather than do a new search for clear greenI've never found conversion charts to be much use.
You're probably right, it would be a massive task, I might have to think about it more.I fear you could be making a rod for your own back. Keeping it up-to-date could become a nightmare
I know what you're saying John, I was just trying to point out how I think many people would interpret it.As I’ve said it’s not a conversation chart, in this case, it’s all the other clear greens we stock. The way I thought it would work was, if someone searched for example C138 clear green and it was out of stock, you would see the alternative listed below, rather than do a new search for clear green
It’s nothing like a search engine, as per the picture it would show a list of other brands of the same colour, none of them listed would be out of stock, we use live stock levels and it would only show in stock items.I understand what you are trying to put together which is basically a search engine
