1/35 T34/76 by TAMIYA 35049 1942 production with metal tracks !
John Race
Member of Rabble , bed 7
STAMFORD LINCS
john
lincs
Have ordered the Fruil tracks form John , built the kit at the same time as the StuG. So only a few photos.
I was reading earlier some old posts from 2022, boy we had some fun here in those days.
This kit was kindly given to me along with several others by @Richard48, when we all met up at the Stamford Show earlier this year.
So what do I build dio-wise? I had thought of a tank crossing a railway track, but looking back I really enjoyed buildings, so thoughts and ideas please.
Going to have the "lid " shut.
Not bad moulding, I see this model has now been discontinued.
I chose to build the earliest version with the attached armour plate to the front.
And finally those wheels and caps.
Tea and biscuits will be served, hopefully, by Minime and Steve Jones when they have turned up!
Tea with milk but no sugar please and chocolate Hobnobs.
How about the tank travelling through a ruined street. Damaged buildings are a real forte of yours. Simple but right up your street - pun intended 😜
Yay, john is back with the 4BO....
I'll have a tea with one sugar and a mint viscount biscuit please.
How's about the tank sitting just inside a ruined house. ? ambush style....waiting patiently for an unwary Tiger tank to wander past.
Thanks Jim, yes I love buildings and damaged ones even more !
Wouldn't be long would it Chris. Now that's a good idea, well worth considering.
Chair pulled up John, the kit I am building was also a gift for the very Kind Richard. How about it crossing a trench with some figures hiding that will give you a choice of using Russian or German figures.
Hi Paul, I can put a few German creeping up the street. Going to have the T34 hiding in a burnt-out building, waiting for some German armour .
Hi John, long time no see. Yep, 2022 was a good year tackling my monkeys.:p The good old early version of the T34 always looked good in winter camo and with full rubber tyres. Very iconic scenes of them racing through the steppes in mass surprising the germans.
Looking forward to your buildings...SWMBO should be hiding the matches at this point. Would you have any Ginger Snaps to go with my tea?...would fancy some dunked in tea to soften them up a little...teeth are a premium these days.
Wabble
Wabble
Wabble, good to have you aboard. Yes 2022 was a great year., I remember them well. Rick has been asked to find some Ginger Snaps, do they have them in the US ? Don't want your teeth falling out !
Right though I should bore you all with a load of photos ;)
The actual base .
Other makes of semi-skimmed are available
Sat out side and cleaned the track section in the shade
With having only one good eye my depth of field is poor, so to cut the wires I took a piece of soft wood and drill a hole to 15mm
Push the wire in and then cut off
Can only put in 10 max so here are some more.
Next the actual building, made from Kapa Line foam board, easy to peel and by far the best for imprinting
Filler is used , found this in Toolsation, great as my French hero Emmanuel Nouaillier uses this as well.
Some members on here may remember MM magazine doing a complete how to guide from him some years back . I was lucky to find and buy his book Extreme Buildings last year, cost a lot but was well worth it, around £50.
The brick work lines have been drawn and cut into the foam, still using the tool made by Mike Cartwell after I found the one sold was useless
Brick lengths will be done later as on the side there will be a great hole in the side, pointless doing it only to be removed.
Doorway into workshop, this will show signs of damage later.
Spent some time doing those lines !
