1/24 SCALE HELLER FERGUSON Rusty and left in a barn Fergi
Looking forward to the chipping on the Fergie. They were a favourite of the crofters. We saw lots of them when we lived on the Hebrides. In all sorts of condition from pristine to used and abused, all still doing the job they were built for.
Bring on the dio 👍
Umm - not sure about this, but haven't you got the mudguards on the wrong sides?
Love your plumb bob.
Paul, that's the foam cutter wire!
Bring on the dio 👍
Will hopefully start that tomorrow, once I've replaced those rear mud guards, thanks to Pete.
Yes indeed, Pete, thank you. How on earth did I manage to do that? They even look wrong ! Thank you, as soon as I post today's efforts, I'll go and put them the right way round !
Hi all, had a good afternoon preparing the groundwork on the base. The brick wall is up and pinned as the filler dries. Sorted through numerous boxes and came up with a roof structure.
Always add some PVA to the plaster filler, then apply it to the base.
The wall is sitting on a layer of filler, pinned from the back and front side, hence the yellow pin head.
Then some sand was scattered over the whole base, turning the base on its side to remove any loose. Left it for 30 mins then using various wheels marked the ground, including the Fergie.
Since then I've been finding timbers and some poles for the roof and supports.
Comments welcome.
Looking good John.
Excuse my ignorance but what is Paverpol?
Hi Jim, it's a harder , normally used on fabrics to stiffen them , but also used on foam board to harden. It's a water-based polymer fluid for the technical !
That's interesting John. I have some sealer/hardener for balsa wood. Works beautifully. Trouble is it attacks foam board 😳
Yes, Jim, that's why I've gone for the PAVERPOL. I had read about some hardeners doing that, mass panic at that point:eek:
