Geoffs Trumpeter 1/48 MiG-3
I’ve managed a bit more progress 😊
The flaps were added, the fit wasn’t the best so it needed a bit of Perfect Plastic putty to hide the gaps, a few other areas needed a smear of filler too but in fairness the fit is generally good.
Once the filler had been cleaned up and given time to dry it was on to the priming. Black Mr Surfacer 1500 was sprayed on leaving the usual nice smooth finish.
After this cured I sprayed the underside with AK Real Colors 935 which despite being RLM-65 is also a close match to the Soviet A.li blue 🙂
I’ve also painted most of the ancillary parts - undercarriage, spinner etc so It is all starting to come together nicely.
Upper side to be painted next, hopefully another update soon.
Thanks for looking 👍
Geoff.
Some nice detail going on Geoff. Will it be flaps up or down on the finished model.
Cheers Steve 👍
I’ve done them in the raised position as in most of the pictures I’ve looked at they are like that.
Geoff.
Come on Chris, get it sorted, it’s too pretty to sit on the shelf 😂
Geoff.
Yes, but to misquote Douglas Adams, 'What colour should it be?'
(always wanted to do a ww2 soviet 'plane in badly applied white wash...)
Transfers and weathering have been completed so I’m calling this done now 🙂
Well, I need to add antenna wire but can’t find my rigging elastic at the moment 🙄
The transfers went down well but are very thin to the point that the white numbers are a bit translucent which is a shame.
Apart from that everything has been pretty plain sailing.
The gun barrels as supplied with the kit were just pieces of solid plastic so I replaced them with cut sections of a 20g needle.
I’ve kept the weathering fairly muted, here’s a couple of pictures, I’ll post a proper finished thread later.
Thanks for looking
Geoff.
