Revell 1/48 B-25J Mitchell “Jaunty Jo” - My First Big Build
WELL Renat it looks ok to me very well done sir as yes ive been moddeling for 60 odd yrs an yes ive built this plane several time over an a few months ago i built the USS HORNET with x 16 B25's on it in 1/200 scale as the build is on this forum an i can say i was mighty glad to finish building them x 16 B25;s an the model looks acceptable an had lights fitted in but that was enough for me so glad you are enjoying your B25 build an i will be followin along on your build keep it coming sir
ATB
chrisb
ATB
chrisb
Wow, Chris! That’s quite an impressive project! 😮
Am I right in thinking you’ve recreated the famous Doolittle Raid? That’s absolutely brilliant! It’s actually one of the stories that fascinated me the most when I started learning about the history of the B-25 Mitchell.
If you don’t mind, could you share a link to your build thread? I’d really love to see your work, but I’m still finding my way around the forum and haven’t quite figured out how to find specific threads yet. 😄
Thanks again for the kind words and encouragement!
Hi everyone!
Today, I've finally finished sorting out the fuselage of my Mitchell! Well... I think I have, anyway! 😂
As you saw in my previous post, I'd reached the end of the first round of filling and sanding.
To fill the larger gaps, I used Tamiya Putty Basic Type (87053). First, I masked off both sides of the seams with DSPIAE masking tape, then applied a fairly thick layer of putty using a cotton bud. I removed the excess straight away and left it to dry.
Once it had cured, I sanded everything down using sandpaper of various grits and applied a coat of primer to check the results.
And that's pretty much where things stood when I published my first post here.
After applying the primer, I noticed there were still a few small cracks and low spots that needed attention.
So, for round two, I switched to AMMO by Mig Jimenez A.MIG-2049 Putty Surfacer Thick. One thing I really like about it is the built-in brush, which makes it easy to apply small amounts of putty exactly where they're needed.
Then came another round of waiting for everything to dry, followed by yet more sanding.
This time, I was finally happy with the result!
Of course, somewhere along the way, I managed to completely obliterate most of the panel lines. And a special thank you to Revell for those wonderful raised panel lines and rivets! 😂
Fortunately, I was both mentally and physically prepared for this particular disaster! 😄
So, armed with my OLFA XB157P (KB4-P) scriber, an engraving needle and metal templates from the Hasegawa, some masking tape, and a healthy dose of patience, I attempted to rescribe panel lines for the very first time.
As it turns out, it's nowhere near as easy as those YouTube tutorials make it look. Who would have thought? 😅
My first attempt was to restore a panel on the tail section.
Naturally, the result was... less than impressive. But hey, you've got to start somewhere!
I haven't bought a rivet wheel yet, and honestly, I'm not even sure it would have helped much with such a small detail.
So I ended up making the rivets one by one using a simple engraving needle.
Then came a whole series of experiments as I tried to figure out how to rescribe panel lines properly.
I got the hang of using the scriber itself fairly quickly (it's not exactly quantum physics, after all!), but figuring out how to make the lines STRAIGHT took considerably longer.
First, I tried using masking tape as a guide, running the scriber along its edge. Unfortunately, the tape turned out to be too thin and soft, so my lines ended up rather wobbly.
Next, I tried the metal templates from Hasegawa. These gave me much straighter lines, but positioning a relatively large template on an almost fully assembled aircraft was a real pain.
Eventually, I found some old plastic cards, cut them into strips of different widths and lengths, and secured them to the model with masking tape.
And suddenly, things started going much more smoothly! 😄
At one point, I actually had to stop myself from rescribing every single panel line on the aircraft, rather than just the ones I'd damaged during sanding!
Oh, and somewhere along the way, I accidentally broke off one of the wings. 😂
But never mind! Nothing actually cracked - it just came apart at the glued joint. And honestly, having the wing off makes it much easier to work on everything properly.
I think my Mitchell is trying to tell me that I was a little too eager to assemble everything in the first place! 😄
Overall, I'm pretty happy with the result, especially for my first attempt!
Not all the panel lines turned out perfectly straight, and I managed to leave a few accidental scratches in the plastic here and there.
But then I thought- maybe I can hide some of my little mistakes with weathering later on!
After all, it's a combat aircraft! It's supposed to have some chips, scratches and battle scars, right? 😂
And finally, I'd like to take advantage of how friendly and helpful everyone has been here and bombard you with a few questions about the techniques I'm currently learning! 😄
1. Filling and sanding​
At the moment, I'm using two different putties: Tamiya Putty Basic Type (87053) for larger gaps and AMMO by Mig Jimenez A.MIG-2049 Putty Surfacer Thick for smaller imperfections and final touch-ups.
I've been applying the Tamiya putty with an ordinary cotton bud, simply because I haven't found anything more convenient yet.
So, I'm curious — what do you guys use to apply putty?
I've seen all sorts of tools in tutorials: toothpicks, silicone brushes, spatulas, and pretty much anything else you can imagine!
Do you have any tips or favourite tools for applying and smoothing putty?
I've also seen people thinning Tamiya putty with liquid plastic cement. I currently have Italeri 3990 Liquid Cement for Plastic and Tamiya Extra Thin Cement (87038).
Is there any benefit to thinning the putty with either of these, or would you recommend using it straight from the tube?
2. Rescribing panel lines​
I recently bought an OLFA XB157P (KB4-P) scriber. To be honest, I simply went for one of the cheapest options, since dedicated scribers from Tamiya, DSPIAE and Mr. Hobby can be rather expensive.
What confuses me a little is the variety of blade widths available: 0.1 mm, 0.15 mm, 0.2 mm, 0.3 mm, and so on.
Is it worth investing in several scribers of different widths, or is one general-purpose tool enough?
Can you control the width of the panel line by making several passes with the same tool, or do different blade widths make a noticeable difference?
I'm mainly interested in building aircraft in 1/72 and 1/48 scales.
And one more question: what do you use as a guide when rescribing panel lines?
Is there a more convenient solution than cutting old plastic cards into little strips? 😄
I'd really appreciate any advice, recommendations, or tips from your own experience.
Thanks in advance, everyone!
HI AGAIN Renat here is a link to my hornet build for the dolittle raid on japan
an this is in ships under constuction section
an here is the title
Boatmans 1/200 scale USS HORNET CV8 BUILD AN LIGHTS for the Doolittle raid on japan
chrisb
Excellent filling work Renat. I use a small metal tool, I think it was a tiny makeup applicator once upon a time. I use the Tamiya putty as you have, but for small gaps, I use Vallejo acrylic putty. Looks like you've got the hang of filling, so stick with what is working for you.
Thanks a lot, Joe! Really appreciate the advice and encouragement!=))
I actually tried using a small paint spatula to apply the putty, but I found it a bit awkward and harder to control how much putty I was applying.
So far, the humble cotton bud seems to best for me! 😄
And you’re absolutely right - if something works, there’s probably no need to overcomplicate things.
Thanks again for sharing your experience!
