Problem using Clean Spirit from B and Q to make oil wash.
Bob Pringle
Scotland
The Clean Spirit (Odourless) does not dissolve the oil paint. Windsor and Newton Sansodor works fine. Is Clean Spirit no good for mixing with oils to make a wash?
Clean Spirit is water based and oil and water don't mix.
As Jim says. White spirit will work, but it’s pretty harsh on any underlying finish, and can even debond glued joints if you are unlucky. If you have it, Sansodor is best I think. Ive used it for years with no issues.
Thanks guys. I just assumed Clean Spirit was the same as White Spirit or Turps without the odour. I guess the "odour" must be the dissolving agent. Silly me!!
