Thanks Jim, we will see----Pouring resin. Fingers and everything else crossed for no leaks![]()
Cheers Joe, it is, but you always think will it !!!This is an exciting stage John, good luck.
Thank you so much, SteveComing along well my friend. By the way the answer to 5 across is STRICT![]()
Well, Tim, that's not a bad idea.I had resealed, having removed the first strip and using hot melt glue as suggested on AI . I'll try the pva once that first pour has dried.Looking good John. Not done this myself, and I’m just thinking aloud here, but would perhaps brushing some PVA into the join between the clear stuff and the dio seal the area better before you pour the resin?
