Hi everyone just a quickie is there a sure fire way of restoring these yellowed decals. Any info gratefully received . Cheers John View attachment 260802
Option 1 (I use this for old yellowed decals): Place the sheet in an air tight plastic bag (a snap lock bag is ideal, this is to keep moisture out). Face the decal sheet to the outside of a window that gets lots of sun (avoid direct intense hot areas) and tape the bag to the window. Let nature's UV do the job for you. This can take days, weeks or even months. Looking at your sheet you are probably looking at weeks.
I've found the decals can become brittle (apart from their age, sunlight also can cause this. Once the carrier film is bleached white again, I recommend spraying some decal bonder or your favourite varnish on them. I did this for the old Canberra I recently built and it prevents the decals from disintegrating..
