Well one build is never enough, so here's one that I've been working on for a while, off & on.
This is an excellent kit, the detail is fantastic. As with most recent Dragon kits, the instructions leave a lot to be desired & there's so many unused parts that the combination can lead to mucho confusion!
As is my wont, I start with the lower hull & tracks. I prefer this method as fitting the tracks after the fenders are on can be extremely tricky.
First a coat of German Grey, followed by a medium grey to add depth.
Then I added some dust effect with my airbrush using Tamiya Buff
Next up, I began to make up the Magic Tracks.
Using masking tape as a backing makes it easy to bend the track run around the sprockets & add sag. Once the cement has cured, there's still enough flexibility to remove them for painting.
Thanks for looking in
Patrick
Patrick
