**SCRAPPED**Hobbyboss 1/48 Ta 152C-1+Eduard PE
The Ta 152 was the best piston engined fighter of WW2, but sadly did not see mainstream prodution. Designed by Kurt Tank of Focke Wulf, this was a thoroughbred of the Fw 190D-9 fighter
The C-1 version was the most heavily armed variant.
I am now building this aircraft, this is by Hobbyboss and in 1/48. Fit is generally good and the cockpit is shaping up rather nicely. However, they should had provided more sidewall detail, but the eduard PE supplied some. The Main control stick is yet to go on.
Criticism is welcome
I didn't superdetail it as the cockpit is very enclosed.
The same is for the half engine plug
Cheers, John
That looks very nice to me John. You're right about the cockpit, it's very hard to see into once its built.
This was actually the original aircraft, the Ta 152V6. It never got past prototype stage It was named VH+EY, a classic prototype name for experimental aircraft
I will be posing it exactly like this, with the cooling gills open and the canopy open as well.
Looks like you have done your homework on this one,off to a good start it's looking great
Thanks mate
Did some progress on here. The undercarriage wiring and oleo sissors are notoriously difficult to fit, due to the fiddly wiring and the two part nature of the oleo sissors.
Extra yellow wiring was added into the Undercarriage bay and the fuselage was mated together, and the same was done for the wings. it was then sanded down and the panel lines were rescribed using an RB productions scribe R. Washes were liberally applied to the inside of the undercarriage.
ALL ASSEMBLED PICS ARE OF A DRY FIT
Cheers, John
The undetailed undercarriage
The fuselage, upper cannonbay, nose and wings were mated together to the main fuselage today. The fit was good, but not perfect, and marginally needed some filler along the wing roots. However, the cannonbay's fit overall was pretty good.
This was followed by a priming coat of Mr Surfacer 1000 followed by pre shading in Gunze Mr Hobby Tyre Black. The pre shading was deliberately wavy, as a judge at a model show once told me that once the paint went on, it would break up the surface and make it look more natural. I don't how true this is, but I am about to find out.
I purchased some hollow aluminium tube and replaced all of the guns with it and in my opinion, were a definite improvement over the stick like kit ones.
Some good progress there John. I'm glad that pre-shading can be wavy, coz mine always is!
All looking very nice. But just look at how far back the pilot sits. This must have been a bit of a nightmare to taxi.
Hi John
There were four known prototypes of the Ta 152 C-1 series.
V 21/U2 werknummer not sure would have to dig it out :) , stammkennzeichen TI+IH, Rebuilt as an engine test bed,first flight 3/11/44.
V 6 werknummer 110006, stammkennzeichen VH+EY, first flight 12/12/44.
V 7 werknummer 110007, stammkennzeichen CI+XM, first flight 8/1/45.
V 8 werknummer 110008, stammkenzeichen GW+QA, first flight 15/1/45.
These are the only four of the planned 17 prototypes built.
The entire aircraft industry in Germany was a complete shambles by this time and it is often difficult to be sure of what got built or what happened to it, but there is reasonable documentary evidence for these four.
Cheers mate, it probably was problematic to taxi, but it certainly performed brilliantly in the air....
Hi John
Interesting how hobbyboss only provided one scheme. Bit of a pity how they didn't provide more schemes. BTW, where are those sourced from? Been trying to build up my reference library again.
Cheers, John
new update, the main camo has been completed and the framing on the canopy has also been completed. All of the main upper stencil data has been applied apart from the hakenkreuz. All paints used was Mr Hobby. Some Mr hobby Buffable Aluminium was used on the underside panels. All of the painting was carried out with my Iwata Hi Line HP CH. A flat coat then sealed the decals on the upper surfaces.
Tomorrow I will be doing weathering with my new Mig Washes and completing the decaling. Hopefully, the undercarriage and bits and bobs sticking out will be attached as well by tomorrow followed by a complete flat coat.
View attachment 257213View attachment 257218
Hi again
My two principle Ta 152 books are Dietmar Harmann's (Focke-Wulf Ta 162-the story of the Luftwaffe's late war high altitude fighter) and Thomas Hitchcock's (The Focke-Wulf Ta 152). Neither are perfect, but such was the confusion at this late stage of the war some 'facts' are always going to be open to interpretation!
