The trains section
Staff member
Admin
Falster, Denmark
As most people look in here to see whats happening a quick heads up.
The section for trains has had a bit of a lift. In short there are now sections for trains and rolling stock, under construction, and completed.
Also under Layouts they have also been split to Under construction and completed. There is a new bit as well. Buildings.
Here you can post your treads on the buildings you are, erm, building and a place to show them off before you plonk them into the layout.
Houses, factories, bridges tunnels, all that kind of stuff.
Pop over and have a look.
If you have a tread in there, feel free to move it (if you can) to the most relevant section. If you can not move it send me a quick PM with a link and I will move them for you. Also if you have things hidden away in that junk heap called Other models that you think should be moved to one of these sections.
Hi Ian!
I will start a small diorama today. All the set will be done with craftsman kits at 1/87......
So...if is itok, I will post it there :)
Hi Ian!
Well there is a diorama section..... Seems that it is only being used for military diorama. You could put it there....AS we are all to aware of there are not to many that use the train/railway section so I dont know if it is a good idea or a bad one.
I must admit, I thought that your buildings where for your layout...
Hi Ian.
I moved the thread to the diorama section!
Jaja! Some of my buildings are for the layout,, but those news are for a small diorama. Anyway, maybe, I can add them on the layot later as well.... ;)
