Hello,
So over the weekend I purchased my first Tamiya tank after deciding to get back into modelling, which has been at least 10 years ago when I was about 16.
I've finished building the tank but have left it in separate pieces for ease of priming and painting.
Just a few questions and some advice needed before I get started on this.
Firstly, what brand of primer should I go for? Anything along the lines of Black or Dark Grey.
Secondly, I have read a few posts about mixing Tamiya Dark Yellow and Deck Tan together to give a better overall/accurate colour than a straight Dark Yellow base colour. I would then like to add a filter to this but I am not sure on which filter I need?
Final question about weathering. When adding pigment like AK Track dust, do you always mix it with white spirit? (I know AK have their own white spirit but not sure if any old white spirit will do)
When adding AK Rust Streaks, do you always use a little bit of thinner by itself on a brush to blend it? And if so do you blend while still damp or once its dry?
That's all my questions for now, I apologise in advance as I'm sure I will have a few more. I like to be thorough and know all I can before starting things like this lol
Thanks again.
Thanks again.
