Steves shilka
They utilise the "spray 'n pray" targeting system. Put eneough lead in the sky and you are guranteed "a" hit. o_O
It appears that they are deployed in battery's rather than as single units.
Well, for all it's real life shortcomings it looks like a fun kit to build.:)
true so my advice is DO NOT HIDE BEHIND THE BUILDINGS stay in the sea under water , in an under water home, that way it can not hit you:D
this part i agree with you steve what you found by plato "Only the dead have seen the end of war." - Plato
push them together very gently or use twisers like a shoe horn like putting on shoes that's my suggestion for you steve
The masking tape method might serve you well Steve.
Lay a length of masking tape sticky side up & add the track links to the tape. Once your run is enough, add liquid cement to the gaps. Once the cement is nearly dry, bend the length around the wheels. The tape gives support & helps keep everything in the right place.
Thanks, did think I might try that, won't need glue as they are workable
These tracks are so easy to put together, now I have found the correct process. Through trial and error I discovered that the nibs are not the same size, the right hand one been ever so slightly larger than the left one, so insert the link into the right side first then the left link just pops into place. All that's needed first is a quick file and then snap into place. Made 7 runs if 10 in less than 40 minutes last night.
View attachment 273924 View attachment 273925
Just caught up again Steve, nice work so far, and the tracks look great.
Tracks and wheels done - for me this is the hardest part of AFV kits so well done there Steve, Good luck with the rest of the build.
Started putting bits and bobs onto the chassis last night, couple of parts, dont have any locating points just an arrow on the instruction booklet pointing to where the parts should go;
Also seems that certain area's have been over engineered, for example - the shock 'units' are made from 3 pieces, yet the finished unit is buried in the sides of the chassis - so you only see the front face, also had a few fit issues as well, not helped by some of the sprue attachment points.
