Excellent progress Ian. I was hoping to finish off the Triumph today so I could give Bizzy a bit more attention but I have fallen to the dreaded man flu so will be out of action for today at least
I am using micro scale krystal Klear . Just s drop on a cocktail stick then run it around the hole and it will fill the hole and dry to a clear film. The best bit is that you can do it after painting. Great for jobs like this I have managed to do a window that was 6x10mm with it but bigger than that then the surface tension cant hold it any longer and it pops.What are you using to glaze them?
That is no way to think Ian! I'm only doing all the window malarkey due to the scale (and because I want to, OK I'm mad). So get on and open the thread and get on with it. Graham and I are getting lonely in her with only Russel. Where are all the others....? early days yet.have I got all this to look forward to when I start my Tirpitz ?
I think I may just put it back into the stash.![]()
Just caught up Ian, and what a lot of work your putting into this. I'm liking what you've done so far, but have I got all this to look forward to when I start my Tirpitz ?
