Cheers Pete!The cap doesn't seem loose on mine Jens.
Thanks John for your detailed story on how you found your solution! I'm about to make your, and many others, journey and I'd prefer to not have to buy several different airbrushes before I'm happy. It's money I don't have to be honest and if I'm going to spend ~£200 on an airbrush it better be one I'm happy with.
Looking at the Iwata I've found three models that would suit me according to their descriptions and they are High Performance Plus C, Eclipse CS and HI_line CH.
However I'm very happy with my current "cheapo" H&S and how it's easy to disassemble so I'm currently in favour of that brand due to inexperience with everything else...
Before I wrote this question I was looking at the H&S Infinity CRplus Two 0.4 mm but only based on my gut feeling and my experience with my Ultra, and thanks Tony for your words on this model!
As long as I can limit the air flow and paint volume I think I'm going to be happy, but getting an airbrush that's going to last me a very long time is also important so I will spend a bit extra on quality for sure.
I think I'm going to consult youtube a bit later tonight when the kids have gone to bed in order to see the above mentioned airbrushes in action, specifically cleaning, and make some sort of decision on that.
Thank you!![]()
I do. Myself and Jens bought the same AB quite independently at the same time. Just about an hour ago I used it for pre-shading a 1:72 model. I've done this before, but it was so much easier with this AB. The 'quick fix' facility was used a few times - I spray Vallejo !Given the price of the Infinity, do you feel it was worth it?
The only other decent (I don't think it counts as high end) AB I own is a H&S Evolution Silverline fpc 2 in 1. I'm leaving this set up with a 0.4 needle for primer etc. The infinity is more adjustable and has a quick fix function (very useful for acrylic users like me) Crucially, I can do finer work with it, well I say that, I need more practice using it, but early indications are very satisfying.Good to know! If you don't mind me asking, what other higher end AB's do you have experience with and how do they compare to the Infinity?
Oh yes! This is the airbrush I should've bought from the beginning and not the Ultra, but I've since put a 0.4 mm nozzle and needle in the Ultra so I'm using it for primer etc from now on.Given the price of the Infinity, do you feel it was worth it?
