Hi guys just need a bit of advice apart from rigging wire which I have for rigging a bi-plane, I know I need to buy turnbuckles is there anything else that I need to buy to do the rigging. First time for me. Cheers
I'm not familiar with Uschi rigging but it seems like good stuff. For the eyelets, I just use strip some wire and use a single fine piece and bend it around a former (very small drill will do) and twist. It won't always work, I make a load and select the better ones to use..I got some Uschi rigging. So what are using to make the eyelets. looks good that Plane.
Glad you found it useful. It's not the only way to rig a model, but it works for me.Fantastic suggestion! Thanks Colin, I'll keep that in mind!
