New modeller needs assistance
Hi all I'm very new to modelling, only been doing it for 4 months, so the quality of my builds and painting isn't great however I am really enjoying it so looking to learn more and keep practising so please don't be brutal in your assessment of my modelling efforts. I have recently finished the paint job in this Tamiya Panther AUSF A 1/35 scale and I don't know what decals to use out of what's in the pack, I would like the decals to be a good reference to the correct theater etc... If you could help I'd really appreciate it
The details available I've uploaded in the pictures
Welcome to the Forum Jamie.
Just 4 months in, that looks fine.
No one will be "Brutal", but will give a fair assessment of your Panther. It's not really my bag to write what is wrong with other folks models and where they could be improved. I'll leave that to others.
Also you will pick things up as you go along and your modelling skills will improve accordingly.
Don't be put off by some excellent stuff you see on here, you too will eventually be as good - or perhaps even better. Just be patient.
I can't help with decals as I just stick on what I fancy. Someone will come along soon to put you in the right direction.
In the mean time join in on the forum, enjoy your model making, and have fun!
Ron
Many thanks for your kind words Ron, I have completed 4 other projects in that 4 month period also I will upload pics of them at some point in the near future.
Since you’re not building a model of a specific real tank, you can add what you like, really. The simplest way is to simply follow one of the marking options goven on the instruction sheet. Otherwise, with German tanks like these, all you really need to get it correct enough is to add a set of numbers to the turret, a divisional marking (the white and yellow ones at bottom right) and the crosses in the locations shown in the instructions — even if you use different combination of numbers and divisional insignia than the instructions show. The set of white bands are kill marks (each indicates one enemy vehicle destroyed), so these only make sense if themodel is supposed to be in an area where combat is going on. A tank in Normandy in May 1944 wouldn’t have them, for example, but one in Russia at the same time could. You can also cut some of those stripes off, to show fewer kills.
Hi Jamie welcome to the forum, as long as your enjoying your modelling that's really all that matters, as time goes on and the more you get the bug you will improve, it's a great hobby.
All the best Steve.
You have at least 2 x SS Tank division insignia , 1st SS and 2nd SS.
All the best Steve.
An example of 1st SS panther @ https://www.worldwarphotos.info/gallery/germany/tanks-2-3/panther-tank/panther-tank-in-france/ , ( actually Belgium June 1944)
Many thanks for this information, with the decals I have in the pack which would you apply to my tank
Hi Jamie, did you copy a colour scheme from the instructions you get with the kit. Like the ones below.
View attachment 310245View attachment 310246
If you did it should tell you which decals to use and where to put them. If not I would google the theatre of war you used and it should show you some tanks with the insignia used.
Hi,
Unfortunately the kit I used didn't have instructions on colour scheme etc like the ones you have pictured or previous kits I've used, it simply has a small write up about german military colours and I went with post Feb 1943 which was dark yellow with camo options of dark brown and olive drab as you can see in my attached picture...
Just type into Google Panzers Ausf A post 1943, and it should show some pictures of the Panzers of that era and you can use your decals accordingly.
Hope this helps Jamie.
If it was me , i would use the division sign of ''2nd SS'' , the z on its side. ( allows you Normandy France after July 1944 as a setting )
I would then use only the German Cross , as many tanks by the later stages of the war no longer had the large red numbers on the side of the turret ( if you want nos , i would use the black only version) , or had them covered by spare tracks or any other stowage.
Thank you so much for your help. Really appreciate it...
I’ll add that on the Panther, the crosses often went on the very forward end of the hull sides, in front of the tool stowage even — so basically as far forward as you can get them where they still fit — or behind the front tools about level with the driver’s hatch. On the rear, you can put it in the middle of the left-hand stowage bin on the back of the hull, or in the middle between the bins (behind the tools stowed there).
Hi Jamie
Nice clean build and great finish on the camouflage pattern. For marking references, look at Google. You have a Panther Ausf A as Ian sort of says, but I think he got hit by the spellchecker....should be plenty of images there. If you can find them the newer Tamiya Panther A instructions may be available on line. I built that a couple of years ago and know it has pretty good colour references. Unfortunately I have now got rid of the instructions so can’t scan them for you.
Most importantly, have fun!
Tim
Hi Jamie
Tim
Hi Tim,
Thanks for your kind words, I will definetly look up on Google for more info... I'm happy with my build but know it could be lots better, and I would like to learn the art of air brushing as all my painting is done by brush free hand. That and I would also like to learn how to do whethering as some of the builds I've seen on here are out of this world
That’s always the case. The main thing is to not measure yourself up to what others show off, but build and paint to a standard you’re happy with yourself (this is general life advice, BTW, not just related to modelling :)).
Weathering really is “just” more advanced painting: instead of applying only the colours the model is supposed to have, think about where dirt would go and where paint would wear off, and then try to replicate those effects with paint on the model. Read up on washes (highly thinned paint) and drybrushing (removing most of the paint from the brush with a rag before applying the brush to the model), as these techniques will be a good basis for making the model look worn and/or dirty.
There’s a lot more to it, but much of it really boils down to trying to figure out how the real thing would get dirty and worn, and thinking about which techniques and colours will work to make the model look that way too. Practice is obviously important in getting things to look the way you have in mind, so don’t despair if it doesn’t quite look right first time round :)
Jamie,
Nice looking tank, when I first looked at the pictures - I thought you had air brushed the cammo !! :smiling2:
That's a smooth, neat finish for brush work. :thumb2::thumb2::thumb2:
There is a saying that sometimes floats around the modelling community - basically along the lines of - "It's my model and I'll build it how I want to" !! :smiling2:.
As Steve says above - just enjoy and have fun.
Paul.
:smiling2:
Jamie,
Paul.
:smiling2:
Thanks Paul really appreciate your comments, I have found that I have a very steady hand with a brush and at the minute if I'm honest it's all I can afford, I've thought about airbrushing but with all the decent comments I'm getting on my brush work I might just stick to what I know.
