AFV 1/35 SCALE STURMTIGER.
Afternoon , its too hot to model, tried for an hr after lunch and stood my self down.
Jakko.....Thanks, although I have some ready made on order it's good to have another plan.
Colin.....Cheers mate, that I shall do. I'll have a play on some old plastic card. Thanks for that.:thumb2::smiling:
Hi Jim..... It sure is, the way I see it no one will know if I'm right or wrong. ! Thanks for confirming it was the Skipper.
Ron ..... Sir, thanks I've been and checked it out. Looked very good.
As I'm waiting for a book, tools for the Zimmerit , some Vallejo paint, a cabbage and a cuddly toy, I decided to sort out some figures.
Before I ventured on to the internet I checked the stash. One set of MiniArt tank maintenance crew, unused, and one set of View attachment 310679
Box art is slight different to this , but the figures are the same. I really like these MB figures, they have very thin seam joins, which can be removed quickly. The fingers are nicely sculptured, on some other makes when compared theirs are like large hams, far to thick. I've recently used various arms from kits to make up figures, some of the left overs are far to heavy to use with the MB.
Hopefully it will get cooler this week, I don't know if anyone else has noticed when using the TET glue they are having to hold the parts together longer.
Cool drink time .
Thanks for looking in .
John.
Home made zimm is satisfying when it's done but a real pain while you're doing it. Any one tried the pyrogravure method?That's fun!
Think i'd go down the ATAK route next time.
Jon.
Hi John, nice big assault gun , I'll join the back row with a ladder next to Richard and Steve.:smiling:
Nice start at the construction and good luck with the zimmerit.:thumb2:
Looking forward to see what you've got planned with those figs, maintenance dio after some action?
Hi you two :smiling:
Jon.....No not even thought of that ! What's ATAK.BTW ? Before I go and look .
Fernando .....Hi , you get the prize of the week , sorry can't post it , dam, I'll eat it for you.! Yes I thought , Sturm in a building, tracks being adjusted, reloaded. I've just ordered a workshop kit by Tamiya
And
And View attachment 310697
I had the last one before and used the figures, but it has a correct engine ! Just need some figures for loading the shells.
John .
John,
This is going to be another masterpiece mate.
Hi Paul.
Thanks.
The heat has got to me, I've just ordered from John two sets of figures, as they both have a figure that I need for the loading. The remainder will come use at some point.
John.
Hi John.
Atak (and others) do resin zimmerit sheets for specific models inc. the AFV Club Sturmtiger.
never actually used it but looks good from what I've seen.
Jon.
Far be it from me to question your integrity, but your sure it's the heat and not a few bottles of something:smiling:
Jon.
Ah the resin sheet, thank you, bet it does look good. Something to consider if this goes t****p
Paul.
The only drink I've had is tonic water...... Yes on its own, purely for medicinal purposes. :upside: at the moment, by the time I get this Zimmerit on it will be with the Gin ! :cool::thumb2:
Greetings from the hot house.
Today the our friendly postman delivered 2 packets, he once said to Christine "he's been on the net again" .:smiling4:
From Pete Low a set of 2 Sturmtiger shells, thanks to Pete.:thumb2::thumb2::thumb2: Just shows how good the modelling world is .
Nicely molded , any ideas of the color anyone ? book not here yet.
The second package contained the Trumpeter Zimmerit tools, only plastic, but work ok . don't think I will use them very often so that will be good enough. Didn't take long to put them together either.
Of course having built them up you have to test. So using a scrap section of foamboard and the Uni-bond. A very thin smear was put on to the board , and then I tried the tools. Seem ok, but the uni-bond dries very quickly in this temperature and it was vert thin.
Ok there are some ridges, I 'd just run the tool down the board. It appears to me that the uni-bond was too thick in the centre , hence those ridges. Practice is called for before the real application.
Now for some of the figures. These three are from MB, stunning detail all over, and easy to clean up the seam lines. The chap sitting has had a Tamiya arm fitted . Why you my ask ! well his arm was used else where, because it looked good on another figure.
However the Mini-Art appear to be slightly larger and although the detail is good the don't clean up as well. On both set the faces are really detailed.
More equipment and figures on order . I do love it when things start to arrive and a plan is working.:smiling:
Thanks for looking in.
John.
Really looking forward to this build John.nice start with the figures.
Evening John,
How kind of Pete to send you bits. It’s a great community we live in for sure:smiling4: Good to see you tackling more figures...could of sworn you once said never again:smiling5:
Keep practicing with you zimm tools...I’m sure you’ll crack it mate.
Si
Thanks Colin.
Si....... Not bad tools for the price, yes will need to play around with them.
Figures! , love them. Did I really say that, me !
Ask me again in a month.
John.
JonH - I've used the pyrogravure method, especially good on 1/72
Hi John - I got a set of these tools when I corrected the old Tamiya Panther A
this was the result I got on a very thin layer of Duro
Best i can find is
Yellow - Vallejo 882 - not a complete 100% version of Dunkelgelb
Knew i had misplaced a bottle of paint i had
vallejo surface primer - 73.604 = ral 7028 - Dunkelgelb - German Dark Yellow
also found
vallejo surface primer - 73.603 = ral 7021 - Dunkelgrau - German Panzer Grey
both 60ml flip top squeezy ''bottles''
Evening .
Simon..... Thanks . If mine is anything like that I will be pleased !
Gary....... Just went to check, I have some dark yellow MIG 2003, can't find any ref to RAL, would that do ?
John .
Evening .
John .
Looks good to me
Quote from paint description:
"Our water based primer available in a Dark Yellow perfectly suited for use under German Dunkelgelb vehicles and similar colours. Our primer has excellent adhesion and smooth matte finish that ensures that every detail of the surface will stay crisp and the paint will grip over smoothly. Optimized formula for maximum performance with either brush or airbrush. 60 mL jar. Water soluble, odorless and non-toxic. Shake well before each use. Each jar includes a stainless steel agitator to facilitate mixture. We recommend MIG -2000 Acrylic Thinner for a correct thinning. Dries completely in 24 hours. "
