Dave Ward's 1/48 Revell/ICM Mig-25 RBT Foxbat 'B'
I decided to assemble the exhaust 'petals' - the inner petals onto the aircraft, and the outer petals to the final fuselage piece.......................
This was to allow me to airbrush the nozzles - WRONG
I tried to dry fit the outer petal assembly over the inner petals - not a chance. I had to remove the carefully fitted inner petals, then re-attach them after assembling the outers to the airframe - it just goes to show that the instructions are sometimes in that sequence for a reason
Onto tricky masking for the gunmetal rear fuselage section............
Gunmetal sprayed, and masking removed. The Vallejo Gunmetal Grey was not very good to spray, it seemed to cover poorly, and when I peeled the masking off, the gunmetal had crept under! - so more touching up will be needed - so much for my careful masking
View attachment 314532View attachment 314533
When all the touching up is completed, I'll seal all in with a coat of varnish, then there are a lot of decals to add..................
Hi Dave after masking I usually spray the same colour again over the masking tape, so if there is a small gap the paint will fill it. That usually stops any bleed of whatever colour your using next.
Nice work so far by the way.
All sealed in with gloss varnish - rather than masking the rear of the fuselage, I used Bare-Metal Foil for the section in front of the petals
Canopy painted - no masking, just holding my breath......... ( needs a little touch up )View attachment 314599
I decided to do the panel washes before adding the decals, here's the wing underside without a washView attachment 314600
And with a light panel wash..............
I find it best to do smallish sections, then remove excess wash with kitchen towel, wait too long, and it can take a bit of effort to clean off, too early, and you can wipe it clean out of the panel lines.
Rapidly approaching the finish line, a few major decals added to get the positions right - View attachment 314738View attachment 314739
The canopies are still loose, so I can give a satin overspray to seal the decals. I'm not sure about how much weathering to go for - the majority of photos show pristine examples, or really sad looking museum exhibits!
As I approach a finish on this monster, I've decided on my next build, for the Forum GB: Wheeled Military LorryView attachment 314899
I've made a fair few of the ICM trucks, and enjoyed them. They're not 'shake the box' builds, and can be quite challenging.
Construction will start on completion of the Foxbat
Undercarriage and wheels finally added.............................View attachment 314957View attachment 314956
The reason for the Mig-25 RBT - camera ports in the nose ( awaiting clear parts ) The grey panels were made by painting clear decal sheet, rather than trying to hand paint/mask
Undercarriage doors to add ( & those camera ports ) before a final coat of satin varnish. There are still a number of aerials & sensors to add - very fragile!
Phew! Finally finished! Pictures in the completed aircraft section.
Thanks for looking in..............
