Thanks Paul.....Outstanding. PaulE
Hi mate, and thanks. As for the roof, it will be on, the doors will be bi fold and 4 in total will be open with lights inside . always wanted to do something like this and seeing Stevens trench mortar and how good that light was was the trigger. Going to need about 3 or 4 lights, have to work out the wiring, probably with Fernando's help .Hi there John what a great progress the figures looks good the wash certainly helped to bring the facial expressions out ! Well done mister! The scratch built building is stunning, have to say you have a lot of patience to carve all those bricks in ! Will be a great scene! Are you planning to live the roof open so you can see in ? Regards Danny
Thanks for that Danny , i've emailed them.:thumb2:Hi john great idea ! Check this website out for lights , when i built the control tower i get the lights from here ! You can buy it pre wired and also with a battery and switch pack and its less then 10£ look around hope it helps!
https://www.smallscalelights.co.uk
Regards Danny
Your welcome John! Just a suggestion to think about... i do see the doors will be big however if the roof on an all the sides visibility will be limited ! I think you should make one sidewall off or just a little frame that way your scene will be visible for the viewers! That’s what I did with the control tower! Hope didn’t offend you! Regards Danny View attachment 314938
Danny
Thanks Peter.Terrific work John - good to see you getting down and messy too. Lots of good tips there.
Peter.
Hi Jim..... Thanks for looking in. Once dry I store it in a jar, then spray a very light coat of flat/mat varnish on the base , then scatter very thinly over the still wet varnish. Then turn the base over and remove the surplus.The thinner the application the better, you can always add more if required. I suppose you could use pigment fixer, If doing this on the hull sides, but I think the varnish coat for thin applications is just as good. HSH.Hi John
Cobbles are looking great. That fine soil Wolfgang showed us - do you use it dry like pigment or mixed to a slurry? Another masterpiece in progress.
OOH Temptations. Thanks for that Danny. I liked the gen right hand side.Probably the first MMK kit is the best option its only 20€ and loads of things in it! Hope it helps! All the best Danny
