As far as I know they are the same as Tammi's...and though they are called acrylics, the smell tells you otherwise. Best ones to spray though. And use a mask with decent filters because it's nasty stuff.
ps: good to read you back Si ^^
How do you figure that? Because Tamiya paint smells, it can’t be acrylic?though they are called acrylics, the smell tells you otherwise.
Solvent borne usually has higher pigment density as well, so should give good coverage....keep us informed :thumb2:
Just tried real colours olive drab with a VMS acrylic thinners - turned to a gluey gel. So do not recommend this mix. Will try again with water.
I used the AK Real Color Modern Russian set on my Zvezda MSTA-S recently - I used normal tapwater to thin & spray itView attachment 320111View attachment 320110
