Hello all
I am working on a diorama with a SAA BMP - 2 In outskirts of A,leppo scale is 1/35 period is not set but will likely be in the later stages of the Civil War. Discussion regarding the layout can be found Here, but in short there will be a lower building in the foreground - partly in ruins and a large apartment/ storefront complex in the background, also partly destroyed.
BMP: will be parked and crew talking to troops on the ground, believing the area to be cleared - not so....
Materails will be a mix of foam and plaster - working in foam is a first for me.
Lower Building:
Is going to be a grocery store/Bodega with large opening blinded by rolling shutters - the roof will be collapsed so not much of the interior will be seen
I have begun work on the lower building, for ease of construction, I have not glued the parts together yet , also I am planning to have the facade rendered using - hmmm- plaster of Paris I guess - any better alternatives? with parts of the brickwork showing
The Window is thought to be a display window or a smaller opening to serve patrons.
I had to redo the sidewalk a few times but I fairly content with this:
Lower Building:
