Did you see them coming?
Paul , Bored ! Never mate, it's always interesting to follow and see what you can come up with .
Please Carry On:rolling:
Cheers, Rick H.
Rick, Thanks mate.
I tend to agree about molded clutter. It's a potential short cut, but never seems to live up to its' marketing. Usually doesn't fit w/out work or look as good as discreet stuff. PaulE
Yes I agree I doubt whether I will but any again.
Great work as always Scottie nice aftermarket stuff I always enjoy adding that kind of detail.
Hi Lee, thanks mate, I think I will stick to making my own in future.
Thanks John, Keep on following but don't expect to much.
Hi Scottie - etch ammo always looks a bit flat to me, because it is I suppose :rolling:
This set has some nice looking guns and ammo Miniart but even the vintage Tamiya US weapons set has some passable ammo belts
I was about to say that too. In small scales like 1/72 it’ll probably work fine, but in 1/35 I find it’s just too obviously flat to look good.
Yes, as Simon said, their plastic belted ammo is pretty round. I use their 30cal. for 20mm in my scale. Doesn't look bad. PaulE
Thanks Simon, I will look into that set for future use.
Hi jakko, your right its one of the many things that etch is no good for.
Paul, Its good how things can be repurposed from one scale to another.
Scottie, I know exactly what you mean. 1/35 scale 20mm turned brass and aluminum barrels are perfect for 37mm in 1-87 scale.
Thirty years ago, I disagreed with that and used Verlinden etched ammo belts on models when I could afford to. Now, I don’t think I would :smiling3:
Jakko, I like to use etch as you know on my builds but a vast amount on the sprues is never used as the kit part is more than adequate or can be better represented with wire etc. I suppose in hind site I could have tried to impart some depth to the rounds by pressing a small drill in to them.
Rick,
I have never really given this much thought as I only ever do 1/35 but does make for interesting reuse of some things.
Agreed, most etched detail sets I’ve used over the years had a lot left over too because etched parts simply aren’t the best way to represent a lot of things.
I was thinking too that it should be possible to emboss them to make them round(ish) and so a better representation than just the flat parts. But if it’s already stuck to the model, it’s maybe a thought for the next one :)
I was thinking too that it should be possible to emboss them to make them round(ish) and so a better representation than just the flat parts. But if it’s already stuck to the model, it’s maybe a thought for the next one :smiling3:
I might be able to unpick it and see what I can do. But your right it is a thought for the future
Hi Scottie
Nice paint job. Gentle with the airbrush has given nice tones and allowed the preshade to show.
