Shenanigans 3: Tamiya M8 and Willys Jeep
John - Thanks and no problem re the insult!
Ralph - Something a bit different.
Lee - Many thanks also.
Hi Peter,
Finally caught up with your number 3..... Stunning for''Out of the Box'' love your painting work......... look forward to your Jeep next..
Cheers Mike :sleeping::sleeping::sleeping::sleeping::sleeping:
Cheers Mike.
Here's the jeep so far:
View attachment 328413View attachment 328414
Apologies for the indistinct photos. More time consuming than I thought it would be - the seats seemed to take ages. I did include the main bulk of the engine, mainly to give the drive shafts something to connect to and also to add some weight.
I got glue on the windscreen glass, which was too thick anyway, so I replaced it with plastic from some fruit packaging. I would have preferred a solid clear plastic windshield where I could have just painted the surrounds since the inserts look slightly messy from the rear - OK if they're hidden in a cab, but a bit open here..
Hi Peter, a bit late in following your next armour project…
The M8 looks very nice and clean, great looking stowage too.:thumb2:
Looking forward to see how the Jeep turns out.:smiling:
You could put a canvas cover over the windscreen and fold it down onto the bonnet.
Peter...you'going so fast that I'm just about to comment on the M8...what's there to comment, it looks just like what the other guys do with armour here but I can see your touches on the storage painting. Nice work.
...now where should I start on the Jeep. :thinking:
Fernando - Many thanks for looking in.
Jakko - Yes, that is an option, and I have done it in the past. However, I hoped that the carbine mounted above the dashboard would cover the worst part of the windscreen, as indeed it has. Phew!
Richard - Thank you. I'm a long way behind the majority of armour modellers here though - it's not easy is it?
I took advantage of better light to re-photograph the M8:
View attachment 328543View attachment 328544View attachment 328545
On to the jeep, and the main build is done:
View attachment 328546View attachment 328547View attachment 328571View attachment 328572
I started today's session by weathering the basic build before adding the decals and equipment, which were weathered in after fixing to match. As mentioned, the carbine mounted above the dashboard hid the worst of the windscreen fit, which was a relief. I decided to go for the 30 cal option as it adds a bit more interest.
I also decided to use the wire cutter provided. Tamiya just supply one length of triangular bar, and as most seem to have had bracing struts added, I decided to make some from scrap plastic. Most of this type of modification was done in the field using whatever was available, so I've tried to depict it as un-painted and slightly rusty looking.
I also managed to make a couple of bonnet clasps from entrenching tool handles mounted on card plates. Unfortunately I didn't have enough to make the clasps used for securing the windscreen, so perhaps they were never fitted in this case. Also needed was a bit of extra strapping for some of the equipment which was not represented.
Here's how the vehicles look together:
The next stage is to add some stowage to the jeep.
Hi Peter,
Brilliant builds. How did you get the weathering to look so subtle. Like a light covering of dust...... Italy campaign......
Regards Mike :sleeping::sleeping::sleeping::sleeping::sleeping:
Thanks Mike - Any 'subtlety' is probably down to timidity, if I'm honest. I've used a whole range of colours, from black, through a range of greens to white, but I think building up the tones gradually has evened out the effect somewhat. However, I've never been a fan of heavy weathering, preferring instead to try and bring out the details of the vehicle.
I've sorted out the stowage for the jeep:
At least a day's work there.
Hi Peter,
As I’ve said before, I very much enjoy your subtle style on the Vehicles and the jeep is no exception.
Pure eye candy:smiling4:
Morning Peter
Lovely work on the jeep, well done.
Timidity in weathering, shouldn't be an issue, especially if the final result looks so good.
The current Vogue seems to be for extremes in both weathering and chipping, which are the builders prerogative, as it is a hobby.
I guess it will eventually come full circle back to subtle, rather than ""in your face""?
Possibly figures as well as jeep accessories today?
Its all warmer, grey and wet now, up North.
Have a good day with the paint
Regards
Steve H
Probably, though the chipping trend of the past 15–20 years shows no real signs of abating, if you ask me. I just think it’s usually far overdone for a realistic finish. Dirt and grime, on the other hand, can realistically be as little or as much as you like for a lot of military vehicles.
Scottie - Many thanks to another master.
Steve - Very wet and windy here, but warmer. Weathering is a subjective thing and down to the individual. However, there is a bit of pressure to conform to the latest trends, which makes it difficult for the average modeller to achieve a finish they are happy with. Less is definitely more in my opinion.
Jakko - I agree, chipping is one of those 'trends'. As you say, the amount of weathering you go for is a personal thing and I prefer to 'suggest' context rather than overwhelm the vehicle.
Peter.
One look at those photos shouts out Peter Day, the painting is perfect, the detail brush work on the materail, be it the seats or the tarps and packs is done with finesse. Your hall mark.
I can image how they good look in the flesh just by looking at the figures you sent some time back .
Has to be a :thumb2::thumb2::thumb2::thumb2::thumb2: from me .
John .
Well done Peter. Very precise builds. PaulE
