Evening all .
I've broken these posting down as if you do a long one some of the replies get lost, unless the viewer clicks on " show more thingy "
Having to admit I spent most of this morning while some of brave chaps were out working asleep, ! Trouble is I search U tube at night for history and other modelling post. So many good ones out their, at times better than buying a book on the subject.
The KV is not my best attempt at modelling I feel , my fingers are too clumsy and the thin sections of this kit just break off, even though I was using the saw to remove bits from the sprue. The other annoying thing is the glue, you guys seem to be able to show such clean builds. Try as I do getting parts to glue with a small brush used , just doesn't work for me, so I end up putting rather a lot on. Ok most of the surface will get covered one way or the other so its not the end of the world , but It would be nice one day to do a clean build.
So moving on here are some photos, the first show the collection of figures that I seem to have amassed, using one or two here and there has left me with a lot of seperate ones. So following Richard I shall attempt to make up a couple of Germans emerging from their wet and cold lake/ river .
I have a set of Russian troops in full winter kit, but need a couple of guys in the tank, a driver peering out of his hatch and the commander up in the turett . So should be able to find something to cobble together.
Some nice Hornet heads, just hope they will look ok on some of of the torsos they don't always look to scale'
Next a group that look like they may be part of it.
Have a few hats to go through to see if they will be ok .
As only the upper halves will show I think these will do
Right any purists please leave the room !
Had a little trouble getting the two halves together , I see tonight when I was fitting some towing eyes the front plate is not fully down, and the turret has a few glaring gaps that mice could get through.
Notice the filler in the center wheels, the cap short into the air and is some where in a pile of of stuff on a side chest of drawers. Oh the machine gun mount fell off !!! when I was discussing with the turret if it was going to fit or play games, it chose the later so the thing is now glued on ! the turret that is .
At this point I don't know if to attempt the Fruil tracks or keep them for another build, they will fit a SU Few more odd and
sods pieces to fit tomorrow.
Thanks for following , comments as usual , but please be frank .
aJohn.
