spanner's Airfix 1/72 P 51-D Mustang.
spanner570
Here's my next build. It was originally for Pete and Pete's G.B. but because of a problem, I've decided to divert it....:sad:
I'll still be using the diddy pot paints and brush......:flushed:
Started before sprue pictures taken...Sorry.
I've never built a Mustang and never brush painted 'Silver' on a large surface, so this kit seemed ideal to fill both criteria.
However......
Two things.
A - One of the pot paint colours is wrong.
The No.11 is supposed to be silver. The one in the kit is labelled correctly (11) but the colour in the kit pot itself is a very pale blue. Luckily I have a correct pot of No.11 silver in the 'Stores'..... :thumb2:
B - The decals are different to those on the Box Art. which is just a bit annoying. (Instrument panel cut out and applied)
Cheers.
Ron
I've had a think about this and decided, because I've swapped a tub of paint, the build no longer follows the Starter Kit in the box rules, so I've transferred this build to 'Aircraft Under Construction'
Cheers.
Ron
Hi Ron
Odd they mixed up the paint. Still a Baby Blue Mustang would have been cute :smiling2: That no11 silver was the main colour for my Vampire and taking you advice of multiple, well thinned coats, it went on really well.
Silver does settle a bit funny, are you sure it just didn't need a good stir ?
In for a surprise in for a shock Rons on a roll with his model kit stock:tears-of-joy:.
Thanks chaps.
The paint deffo. isn't silver.
Here's a couple of pictures.
This is No.11 - 'Duff Silver' I've given it a good stir. It's stayed a pale blue that's for sure.
Here it is next to some No.11 'Proper' Silver. Although bubby from a quick stir, you can see the silvery bits in the correct paint.
The silver has a blueish tinge to it, so is this a duff batch of No.11? Someone forgot to add the silver bits!..... :upside:
...or simply the correct paint, but wrong number label?
No problem, as luckily I will just have enough silver from the 'Stores' to coat the aircraft.
Cheers.
Ron
Just when you think that Airfix has made every possible mistake, they invent 2 more!
I wonder how many kits they packed that incorrect paint with.
Personally, I'd say your build still qualifies for the starter set GB, since you've only replaced a faulty pot of number 11 with a better pot.
The sport now is to try and spot models, online or even in shows, painted using this faulty batch.
Interesting posts chaps....
On with the build.
I've built enough to start painting the airframe.
Pilot buttoned up. I mixed the supplied red and the green to obtain the brown for the pilot's leathers.
Main wings and back bits glued on
First coat of silver brushed on.
Because it is essential to work quickly when brushing the paint on, things like this will always happen.
Never, ever worry, just get the stuff on! It will be sorted later. Bit of a seam to sort out too....
Cheers.
Ron
Ron, you are a bit of a legend with the brush painting!
Only one coat and it’s not looking bad at all :cool:
I'll follow along if you don't mind Ron, I have some of these in 1/87 scale in the stash. I might be inspired to pull one out and have at it. Yours is coming on strong. Too bad about the decals.
Cheers, Rick H.
Looking good I love to Brush paint and your right get it on and it will melt it’s way in most of the time it will smooth out
Thanks boys.
A leg end? Na, plenty of luck, plus I had a good teacher - My late dad..... :thumb2:
Final coat of the shiny stuff brushed on. It is really nice paint to put on.
....and touched up the wheel wells a bit more to start and remove the wayward silver smudges.
When the paint dried I've rubbed the surface with my finger. This produced subtle dull/shiny shade differences on the 'Metal'
Next I'll start on the various colours.
Cheers all.
Ron
Hi
this was an "Aldi Special" I guess as the decals look like "Rose Marie/Kelly Kid" not "Lollipoop" so the colour scheme is wrong - the decals are for a "Blue Nose" plane
If you contact Airfix / Hornby as I did they will send you the correct decals - go to their web site & look for "spares"
I just finished this one as "Donald Duck" as seen at Hendon (decals by MicroScale)
Regards
Mark
Thanks chaps.
Time to add a bit of 'Pretty' to the aircraft.
I've started on the red bits.
Penciled in first. Then first coat brushed on all wishy washy! If it isn't, the paint is too thick and will cause ridges. I use this application to get a rough line between colours. Don't be concerned about a bit of wobble, these will be straightened with later coats of paint.
The main object is to set the demarcation line.
Cheers.
Ron
Onwards and upwards eh!
Second and final coat of red brushed on and the same for the matt green. Because I paint freehand, I save a fair chunk of time not needing to mask the model.
I've also cut in the paint lines a bit straighter and sharper.
Next up I'll fit the various bits n' bobs. I'm also going to stick the flaps in the down position - Just for a bit of variation.... :thumb2:
Cheers.
Ron
Splendid work and quite inspirational - but not quite enough for me to give up my airbrush. Maybe I'll brush some interiors.
