Si B’s- Revell 1/72 F-14D Super Tomcat
Si Benson
Although I’ve built a handfull of planes over the years, I’m yet to produce something I was happy with.
So grabbing the bull by the horns I’ve picked up a few plane kits and will be blogging a couple.
No doubt I’ll need advice and help along the way, so feel free to chirp in with any top tips/advice:smiling4:
This Revell kit gets good reviews and wasn’t expensive. Just over a hundred bits with an average skill level rating so hopefully should be able to make a reasonable job of it.....famous last words:flushed:
I started this last night and has gone ok so far. The first steps are the seats and cockpit stuff. I’m using a mixture of Tamiya and Vallejo paints as I don’t own any Revell paints.
No decals for the cockpit so I just did some artistic painting.
Hope to get a bit done this afternoon
Thanks for looking
Yes indeed! Very nice start Si :thumb2::thumb2::thumb2:
Steven
Hi Si
Nice looking plane. Great start on the cockpit - looks very good.
Si,
I'm not a wingy person either so will follow this along to see how you get on. If it follows the great start on the office it should be a great build.
Revell’s “skill rating” is based purely on parts count, as far as I can tell, and says absolutely nothing about how easy or difficult the kit is to assemble.
If it’s a Revell kit that’s moderately recent (read: from the last couple of decades), it will probably go together fine, though you may need to remove some flash.
Unless I’m building a model nostalgia-style, I only use manufacturer’s paint references as guides, not gospel :)
Looking very good :) I’d probably have done a dark grey wash and a light grey drybrush before painting the detail, but whether that’s even visible on the finished model is open to debate anyway.[/QUOTE]
Need advice - nothing to offer, that is looking splendid.
Thanks for looking in folks, glad I’ve not done anything horrendous yet:tongue-out:
With the interior dealt with quickly I moved onto the main assembly.
Now I’ll put my hands up, a couple of weeks ago I had a go at building a Ju-88. It started well but I made one or two fundamental alignment errors and it ended up with a visit to the recycling bin:tired:
so I’ve just taped everything together to see how it should all fit before I commit to glue.
I’m glad I’ve dry fitted everything like this as it needs some clean up to get it together.
Some of the panel lines are misaligned and some bits are ill fitting but nothing some sanding and scraping won’t fix.....hopefully.
I didn’t realise the wings fold in a out....cool feature✌️
Puts the swing in swingwing:smiling2: Used to watch these do touchandgoes at MiraMar NAS. PaulE
Hi Si, I couldn't help noticing the skill level 3 on the box cover. Are you sure you're up to this level of complexity
:tears-of-joy: ??? LOL! Your cockpit artistry is excellent sir.
Cheers, Rick H.
Cheers, Rick H.
Hi Rick,
I though I was pushing it going for a level 3, if it gets too tuff the kids can chip in :smiling5:
Hi all,
I’ve been tinkering around with the F14 since the weekend and I’m starting to make some progress. It’s been a bit of a so and so to squeeze together:thinking:
I found the wings where holding off the top and bottom pieces of the fuselage but after much sanding and scraping, I finally managed to get some glue on:smiling4:
Have started the filling and sanding process using Mr Hobby white putty.
I seem to remember my last modern jet build took a fair bit of filler too, also a Revell kit.
I will have to clear out some panel lines that got filled.
Hopefully I’ve not messed anything up yet:upside:
Evening,
Got the rear sections together tonight. Had a mishap on the under side putting the ribs on. but I think I got away with it:thinking:
I was getting a bit fed up with all the sanding and lack of progress but the last few stages have progressed quickly....which makes me happy bunny:smiling4:
Can’t wait to get up to the painting, should be fun:cool:
Quick question....Now I notice in the next few assembly steps is the wheels and stuff. Is it better to leave these off until the rest of paintwork is done?
I'm not a plane guy either, so I'll refrain on commenting on next steps. But liking what I see being accomplished so far. Keep it moving Sir. Rick H.
I was getting a bit fed up with all the sanding...
A good finish is all in the prep ;)
I normally leave off all the stores, flaps, doors, wheels etc off until last thing, to make decaling and finishing easier.
