Now then, back to number one.
Filling and smoothing (and bulge reducing) is mostly done.
His buttons are way too proud, so I have flattened them down with some wet & dry paper.
I’m about to start fitting his belts and stuff so I’ve filed a flat groove around his waist.
I was about to fit the kit buckle when I thought of all the crazy PE work that Steve and Scottie and Mike and others do on their AFVs so I thought I would have a go at the figure equivalent, knowing from my recent painting efforts that the crisper the detail the easier it is to paint.
This is where the internet is fantastic, as with the growth of re-enacting, there is a lot of pictorial information out there to help with details that might be missed even in the most careful of illustrations.
So here is my first attempt, using pie foil as per Andy Belsey’s technique.
I had to trim down some PE buckles which was a challenge, but I only lost two to the carpet monster. The foil is certainly easier to wrap around the buckles than the plastic card supplied. The S-link looks too big now under scrutiny, but I won’t dump it unless I can manage to make a smaller one.
Next came the haversack belt, which needs to look more like cloth than leather, so I used wine bottle foil for that. I should actually have put it on first and then had the belt cross over it, but I’ll get over that. I’m going to sculpt the haversack rather than use the kit version as it needs to be a lot bigger.
I trimmed away the buttons from underneath the belt as the foil shows up every detail and it wouldn’t look right, and I did the same for the cartridge box belt, which I made from the pie foil.
As usual I left him overnight and decided I wasn’t happy with the cartridge case belt. It needed to look stiffer, so I decided to use the kit plastic card. Now, some people have had problems with this, but I never did back in the day. Maybe my standards were just lower then…….
One of the problems with this kind of thing is that, in reality, these belts are slightly curved to enable them to sit flat on the shoulder, and not straight as the template would have us believe. Happily, the foil I used had bent into a more correct shape on his body, so I was able to use that as a template. I stuck it down with double-sided tape and cut around it.
Even more happily, the action of peeling it off the double-sided tape imparted a useful curl to it, which helped to keep it in position.If that hadn't happened I would have scraped the back of a scalpel blade along the card to get a curl.
I then re-made the waist belt after all, this time from toothpaste tube, which is thicker than the pie foil, but easier to bend into the PE buckles than the plastic card.
So that's where we are at the moment.
thanks for looking
Neil
