Thanks, and to Paul tooImpressive stuff. You seem to be well on the way with this conversion. Neatly done too.
I was about to just cut them all off the sprue and stick them on to random mounts, but took one more close look — only then did I spot the length difference. I doubt you’d notice it on the model at all if you did mix them up, though, as the difference seems to be only about half a millimetre.those suspension arms - guaranteed confusion.
Thanks, and I do hope the antislip keeps looking good once there’s paint over itInteresting updates. The turret looks great. The antislip method looks to have worked well. Should look nice under paint.
Thanks againYour research and attention to detail does you credit.
Thanks, and yes, I’m finally getting thereStarting to come together now and look other than oddities, which is pleasing to the eye.
I was first thinking of pulling plastic sheet under a ruler a couple of times, but that doesn’t give all that consistent results. I think I’ll try your method, or use the kit’s front mudguards. The thing is that the kit represents what amounts to a second-generation German prototype. The first generation was very similar to the American ones, so you can argue that a lot of the differences (like the mudguards) would have made it into the actual production version.As for the front mudguards, use the old method of wrapping card around a dowel, and then plunge it inot very ho water for a minute to reall soften it and from there into ice cold water to keep the rounded shape, you can then shape the mudguard to the drawing.
Thanks, and I hope soBe an interesting model when it is finished and a conversation piece.
