not stew again.
Lovely wood grain Scottie. Upside down you say...it happens to all of us. :smiling5:
Thanks Richard, as it happens when I checked it was actual on right it just looked wrong in the picture.
That wood looks very realistic....taking notes :nerd:
Si, Thanks fella glad you like it.
I'm quite happy with the cart. The metal work had been picked out with black grey mixed with a little oily steel. When this was dry the bolt heads where picked out with the same mix but lightened a little with some light flesh. When it had dried a wash was added to pick out the details then finally a bit of dry rust pigment was added.
When the oils have fully dried it will receive a coat of matt clear to remove the shine.
Next I will be working on the lean to on the side of the house.
cheers
Scottie
Lovely work Paul.
I'm about to start my European cart which came with paratroopers and 'Family' to go in my dio. So my note book is out if you don't mind.
Sorry for the elbowing chaps, but I need a front seat.
Lovely work Paul.
Thanks Ron,
It's not the best kit in the world but it scrubs up ok. With your skills you will do a cracking job.
....OOPS! Got it wrong again. My cart is totally different to yours. It's still wood though, just a different shape....should have gone to specsaver.
Lol, the principles will be the same. As to specsavers I thought I had glued something on upside down but I hadn't.
cheers
Scottie
I mean you are happy.... you should be... this is BEAUTIFUL... fantastic...
