Now that I like....a lot:smiling4::thumb2:
Thanks Si..
Cheers mate! That is looking totally awesome. Your onto a real winner mate. Great stuff
Was hoping you would approve, just a note more rivets ,well bolt heads on the way !
Wow mate that looks brilliant, like 3D cinema coming at ya
Mick thank you, that's just the impression I was trying to get:thumb2::thumb2::thumb2:
John,
Love where this is going.
Thanks Paul , if you gets Steve's envelope in your box please sent it on ! :smiling::smiling:
Amazing stuff John. Love it so far!
ASTOUNDING. Just like a freeze frame. PaulE
Great Paul, thank you .h
Excellent stuff 453....and it's not yet finished!
Also, I am pleased to note you are looking after yourself and using Anchor Butter Spreadable (Other spreads are available)
570
570, yes have to keep the old cholesterol down, all this building lark is making me eat more bacon butties:tongue-out3::tongue-out3::tongue-out3:
Damn Dude 2,
Even better than the test shots Buddy!!! You are on a roll with it!!!
Dude 1
Sure am Dude 1, it just seems to be flowing .
Started off very slow this afternoon. Could I get the wire in to the track to do the final join, must have taken 15 mins per side. I redrilled, put bluetac under the join. This is the only time I really struggle with no depth of field. Try as I might, it either went under, over , into one link and missted it's mate. Eventually after sitting the tank in an old tub and turning the whole think on it's side so I could see the hole I was able to put the wire through.
One main wheel fell off, snapped at the join into the wheel, so drilled out both parts ,and gluing some thick wire in a solid join was made. To get those tracks to sit and not be too loose I redrilled the front small wheel just off center and also the body of the tank. This was to fitted with strong wire as well and seems to have done the job .
Cutting into the back of the wall to get the tank through was fun, cutting along the brick line and then bending them outwards. I had to rebuild the left hand window part, thick CA being used to hold the plastic at that angle, and those bricks on the front, I was so pleased that the look worked.
Tonight I've made some bricks, singles and larger sections, these were dipped in a tub of paint and are now drying .
Thanks for the support, really good to have such comments .
John .
