Andy
Looking great you have so many great talents
I prefer to think of myself as a Jack of all trades, Master of none :smiling5:Andy
Certainly BarryWhat is a sure stop with a remote switch ? can you explain how that works please.
What a brilliant idea Paintguy,will certainly consider that for the future,thank you for the explanation.Certainly Barry
Firstly the Surestop itself is a replacement for your existing, tap like stopcock. It has a button on it that looks similar to a household light switch for turning the water on and off. It works entirely off water pressure though, no electricity involved or connected.
A remote switch can then be connected to this, which can be up to 2 metres away and placed much more conveniently than your average stopcock. As you can see, this one is near the front of the cupboard under the sink so very easy to access. Again it looks similar to a domestic light switch but is entirely water operated, with two flexible narrow water pipes running between the Surestop and the remote switch.
I believe there's even a smart version that can be controlled via an app!
I got one from Toolstation for around £55, but they can be found elsewhere. Not cheap but pretty insignificant compared to the damage that could be caused if there was a leak and mum couldn't turn the water off.
Manufacturers site issurestop.co.uk
Pete wise move, normal straight fwd bit if plumbing with a compression fitting, or with plastic pipe is ok.I keep meaning to get one of those. Our stopcocks are in the utility room behind the washing machinery, so a switch above them would make life easier if the missus needs to turn the water off. Trouble is that me and plumbing don't get on very well!
