1/72 Pegasus Paper Panzer P-245-010 - Finished!
adt70hk
Hi all
So this kit marks a new era for me and it's the first one I have painted using one of these new fangled airbrush thingies! ;) I actually did the painting last year but only decaled and weathered it just before coming aboard the forum. The filter was a DIY burnt umber one and very dark brown DIY wash in relevant places. I think the filter worked well but the wash less so...........:(
I chose the kit simply because as a freebie quickbuild kit it was ideal to practice on without wrecking a decent model. I would really welcome your honest opinion of what you think as it is the only way I will learn. I've also included a pre-weathering shot for comparison purposes
As for the vehicle I knew nothing about it but one website I found had this to say about it:
"According to 'Special Panzer Variants' by Spielberger and Doyle it is a Special Vehicle V Porsche Type 245/1. Combat Weight: 18 tons. Crew: 3, Armament 5.5cm rapid fire gun with a belt feed. Designed for AT/AAA targets with an elevation of 90 degrees. Powered by a 10 cylinder gasoline motor type 101 which produces 316 HP. Armour: Hull 60mm Front. Top speed of 65km/h. The design never went past the wooden mock-up scale model – stage of development."
ACW as usual and please be honest!!! :worried:
Pre-weathering
Finished
Heh … I’ve seen that boxtop plenty of times, but only now with these model pics do I realise the superstructure and turret are cast parts. I find them very unappealing, I must say — nothing to do with your building and painting them, which looks good, just that the whole shape of the thing does absolutely nothing for me :)
Heh … I’ve seen that boxtop plenty of times, but only now with these model pics do I realise the superstructure and turret are cast parts. I find them very unappealing, I must say — nothing to do with your building and painting them, which looks good, just that the whole shape of the thing does absolutely nothing for me :smiling3:
I know what you mean. As I said above it was a freebie that I had no intention of building but thought it would be good base to test my then new airbrush on.
Nice one Andrew and smart to test out your new AB on a cheap kit.
What nozzle size and paint did you use?
Thanks very much Fernando.
The AB was a cheap Chinese one that came with the compressor I got. I've been told the needles are often around 0.4mm on these. I knew it was not going to be the best but it works ok and it gave me the chance to play around with something cheap and not risk wrecking a decent AB before I had got used to handling them.
Paints - all acrylics. The 'dunkelgelb' was Humbrol. Brown and green was Vallejo. The filter was tiny bit of artists acrylic burnt umber thinned to almost a water consistency and worked really well in my humble opinion. The dark wash was a 50/50 mix of Revell black and dark earth. Unfortunately I didn't thin it enough but you've got start somewhere!
Thanks again for stopping by.
Andrew.
The dark wash to me looks ok, it's in the right place, maybe a little heavy in one little spot as you mention but has the right effect.
The more we do the hopefully then more we learn. Good start .
Andrew.
Thanks John. It didn't quite work out as intended but I was able to correct the worst of it and as you say only practice will improve my skills.
More nice work Andrew, for some reason they make me thing of egg boxes with a turret :smiling2: :smiling2:
Andrew, That is a great finish. That is not a design I have ever scene before, certainly a strange little beast.
Paul, Mick
Thanks for taking the time to stop by and apologies for completely missing your comments and, yes, it is an old little design.
Sorry to have missed this Andy. Its different and well constructed and painted. What's on the bench at the moment??
