A good morning to you all from a now sunny Lincs !
Tracks are on, slight mishap with one side as I had bent some of the tabs the wrong way , suddenly realising and then doing them the correct way. The tabs are so thin , too much pressure can result on a fracture, so trying to bend them the correct way would have resulted in multiple breaks, In the end I only had 3 . A dap of CA appears to have sorted it out.
Trying to fit those track guards after the tracks was a bad idea, of course the pins clashes with the height of the tracks , so sadly they had to be cut off and them just glued on. Model wise there does seem to be very little gap between the top of the track and the guard, in the photo there appears to be a much bigger gap.
All in all I'm please with the overall look, not as good as what I'm expecting to see from the rest of you.
Next that coat of varnish , then the weathering.
Apologies to StuG fans.
Thanks for looking in.
