Bronco Comet plus bits....
It certainly is Pete I thought he had stopped dressmaking last year.
Taxi for one.
Pete.
Pete/Pete,
The dressmaking is still ongoing, just waiting for my call for the next royal wedding, I thought maybe black with bright yellow for a change..... :rolling:
Mike.
Careful Mike, The Guardian will think you're being racist!
Pete :smiling5:
Update.
OK, rtfoe (Richard) wanted to see how the tracks were painted, So I have put together a quick tutorial and posted it here first, and if the mod would be kind enough to move it to the correct section a bit later, many thanks.
So, "Track painting for those who have nothing better to do with their time..."
I started of with priming the track with Mig Track Primer A.MIG-2007 and after giving it the 24 hour dry time I started the weathering.
Track and tow cable primed and ready.
After giving the tracks and cable a reandom spray with the Dark Rust Deposits, which is an enamel based item (Beware of fumes) I then forgot to photo it. But then did the same with the mediun and light. Again no real pattern to the spraying, I sort of went down the length in a 'Z' wave....
Here you can see the effect and the colours denotes where a stop and start was.
Masking, such a joy... When the wheels of a tank run along the track it leaves a portion of the track in natural metal, where the wheels have a tendancy to move across the track rubs away at the guide horns in the centre of the track. And where the wheels do not touch the guide horns and where they meet the track shoe there always appears to be a line of the original coating left.
So first the outsides were covered up to the outside holes where the sprocket teeth go, this is the wide tape running lengthways. Then next to the teeth and on each side of them a 1mm wide strip (white tape) just visible top and bottom of the central line. This central line of tape was run along the top of the teeth, again where no wear occurs...
The track was then given light coats of metal paint, in this case Duraluminum 77.702 from Vallejo...
The valleho paint dries really fast, so after replenishing the tea mug, I used a cut down old flat paint brush and brushed lengthways down the track with Mig Gun Metal pigments. Once done I blew off the residue and removed the tape carefully - it has a tendancy to stick to the track which was the original idea but it appears it now waits untill you want to remove it...
And this is what you are left with on the inner face of the track, complete with the ejector pin marks that were missed during the clean up process...
Turning the track over it was time to dry brush the outside face of the tracks.
Again a flat brush was dipped into some Model Master Aluminum and the brush was then stroked across some card to remove the excess. This was then brushed across the track and not lengthways. This is so that the detail in the recesses can be picked up. Once both lengths had been dry brushed and allowed a few minuted to dry, I then opened the jar of Model master 'Chrome Silver', again the brush was dipped in and the excess brushed off on the card. This was then dry brushes along the length of the track so that the leading edges of the track picked up the Chrome only.
And that is basically all I do, timewise take as long as you wish, this took me about three hours this afternoon.
Mike.
Update.
The tow cable received the same process of the tracks except for the masking and dry brushing. Once the original rust colours had been sprayed on the whole cable was then given a light brush with gun metal pigments, and I stress a light brushing.
Mike.
HI Mike
Thanks. Very useful and really effective.
Should have moved your cheese and pickle sannies before taking the first photo :smiling: :tongue-out3:
HI Mike
Jim,
Send for the nurse, I am sure the brain has gone for sure - I'm looking at the picture and thinking what the - is Jim talking about.... And then the penny dropped :rolling:... That was a metal block, but when I took the pics it was reflecting the light from my lamp back into the lens, so a bit of bog paper sorted that out....
Mike.
Update,
The build as such is finished, paint is done, weathering is weathered.
Had a bit of a fight fitting the tracks, As I said they go together in no time, but the front track guard has a chamferred inside and the tracks will go past but you will neet to bend it outwards to allow for this, next time I will scratch build one. Also the drive sprocket teeth do not match the holes in the track, not a problem, just cut off the teeth that will not be seen - job sorted.
Would I build another Bronco Comet, unless a better version comes my way, then yes I would and include the track links as well.
So the build is finished, now I am going to concentrate on adding stowage (undecided), cam net and of course a brew kit etc, and then a final matt coat of varnish to seal the job. The crew are on their way from China, rowing I think, and the base is in design. So here are a couple of pics, and once finished the final pics will be in the completed section.
Many thanks for all the comments and for sticking with it. I will let you know when it is in the completed section.
Mike.
Hi Mike
Sorry about the sandwich joke - just came into my head when I first looked at the photo :rolling:
That model is superb in every respect. Great detail and stunning paint job/weathering. Looking forward to the figures and the base.
Perfect. Really fine modelling and painting. It doesn't get better than that.
Up to your usual very high standard Mike.
Next time please finish the wire rope in the correct manor, should be eased into the main length on the return, you have that dreaded Marlin spike ! How I hated wire rope splicing ! Why was your shaving brush out !
Joking apart Mike excellent SBS. Do those tracks just click together, and will they move ie bend easily. I still have problems with gluing them, this afternoon the KV ones fell apart several times. ( Done those exhaust and airfilter .) I would have a go with them if there's not to much dreaded cleaning up ?
Yup stunning it is Mike including the SBS on the tracks thanks.
