HO 80s/90s CSX, NS, & Conrail layout resurrection.
Paul,
I am really enjoying this build the detail you are adding is exceptional as always.
Thanks Scottie. I'm pretty committed to this, but miss the military stuff. Maybe once the yard is troubleshot & in place I'll take a break & do a Sherman company. PaulE
IMO it is good for the Mojo to step back once in a while and involve yourself in something a little different. The best of both being a military RxR with military loads!;)lol. Rick H.
you will have to add some flatbed railcars with some armour on
I have about 18 usable. May not have enough modern armor to fill'em:smiling:. PaulE
Yeah that’s what I’m doing in 1/48 O scale and having a blast doing it
According to Athearn it's a GP38-2. I use it for locals. The coolant sight glass is on the other side. I have another one, w/rerailers hung on it, I use for a yard switcher, two SD40-2s in a double consist for heavy road work, a CW 40-8 & a GP40-2 for fast freight. These are all Conrail. PaulE
Thanks Paul I stand corrected sorry Rick I’m getting old I have the exact same one Paul that chicken wire grill always throws me off
Hi Paul
Just been catching up on this and it really does look the part. Keep up the good work.
Thanks for commenting gentlemen. That would fill them Rick. It's the tie downs that are a PITA. The wood blocking can be fun, but the chain work in this scale is tough. I also would have to prep them for travel. Closing hatches & removing weapons. We'll see how it goes after it's running. Don't want to get off mission right now. PaulE
Working the light maintenance sidings. Sand, fuel, brake shoes, MU cables, etc. & light repairs. More intense repairs/troubleshooting would put them to the next level "out of service" into the MOW yard or on to a regional depot depending on issue & facilities.
Got the lighting wired up and the testing was anti-climatic in that everything worked OK. I must have my +s & -s switched between modules somehow. Will know for sure once the yard is in place. PaulE
Thank you gentlemen. Decided to go ahead w/engine rebuilder complex so big stone building is on the bench for some paint. Once that & sand tower are done I will place the module & retest as the short must be in the control panel wiring somewhere. PaulE
While gazing upon my work w/my first cuppa this morning I noticed to do train assembling I would foul the mainline repeatedly, so promptly redrew the Industry/Maint. Yard module w/main & passing tracks reassigned. This will necessitate adding a turnout but shouldn't require any wiring changes. The change will also streamline activity around the grain elevator & tank farm complex when they are installed. PaulE
