Vallejo Model Air metallics
Mr Bowcat
SMF Supporter
Bob
London
Hi guys,
I found a bottle of Model Air brass in my paint drawer, I think I bought it to do the bolt heads on the inside of a Bradley a couple of years ago. I want to try airbrushing it but never used this brand for spraying before. What do I need to know regarding thinning it to airbrush?
B
I have always found Model Air airbrushes well straight from the bottle, and can obviously be thinned further to suit. Admittedly I have not got any metallic colours from them I don't think.
I spray mine straight from the bottle Bob, no need to thin at all.
Thanks for the quick responses gents, will give it a go neat from the bottle. :)
Out of interest, if I did need to thin it, what would I use?
Thanks for the quick responses gents, will give it a go neat from the bottle. :smiling3:
I use Tamiya thinners, only because that's what I've got. works a treat. you could also use there own brand.
Cheers gents. I don't have or want to buy Vallejo thinner as this is a one of use of their paint.
Ian, is it the X-20A thinner you use? I have plenty of that. :)
Ian, is it the X-20A thinner you use? I have plenty of that. :smiling3:
Yeah it pains me to buy the different brands to suit, just don't use Mr Levelling Thinner...turns my Vallejo to gloop.
Check your needle size. It works best with a .3 or larger needle. .2 works but for that thin the paint a little with Vallejo Thinner. It does not work well with smaller needle sizes.
Thanks for all the advice gents, it sprayed fine neat through a .4 nozzle.
One more quick question, how long does it need to dry before masking?
Ideally in an airing cupboard for 24 hours and prime first on washed plastic.
Thanks Barry. :)
I'd cleaned the parts with IPA before priming with Mr Surfacer 1500. From that point they were only handled with gloves on so hopefully I should have avoided getting finger oil on them. I sprayed the Vallejo last night so will wait until tomorrow before masking to be on the safe side.
