View attachment 376971View attachment 376974View attachment 376972View attachment 376973
Another batch of Dragon figures that I thought were worth re-visiting. A couple of these may turn into a vignette, and the Peiper figure may become a U-Boat crewman.
I'm going to start with the Oberstrurmfuhrer, Budapest figure. Here are the sprue shots:
View attachment 376969View attachment 376970
As with all of Dragon's German subjects, most of the equipment is supplied on generic sprues, which means that you get a lot of stuff you don't want going to clog up your spares box. The panzerfaust is supplied with a full set of decals, but if I remember rightly, they are quite thick and hard to settle onto the tight curves involved.
On with the build:
This didn't go together too badly, with only a little filler needed. The insignia on the cap were poorly defined so I've replaced them with etch examples by Lion Roar. I've added a water bottle and flare pistol to the ensemble, and swapped the ammo pouches for a better Tamiya pair.
On with the build:
