Mike I'm quite positive that last slap around your head by SWMBO has effected you . By now you should have realised that every instruction that says this can be achieved in the smallest time or the smallest amount of tools required is a liar. :upside::nerd:I used mine on the car when I changed the front brake regulator/sensor thingy that lights up on the dash. It had rusted into place, being plastic, yes plastic and all, had to drill it out and then used the Dremel to clean out the bore. The instructions stated that you undo the bolt securing it, then using a screw driver (flat blade) you gently rock it and it slides out.
One tine of wd40, drive the worst out with a drift bar, drill out the rest and then clean up - the guy on you tube did it in 20 minutes, mine took 9 hours over two days.....
