- Joined
- Apr 27, 2018
- Messages
- 15,185
Cheers Gregwell... it's perfect for the OD... can't wait..
Cheers Andrew, it's coming together slowlyOh my that is looking very nice indeed.
Very well done Paul.
ATB
Thanks Steve I'm glad you like it. It is a simple build but full of detail and something different.Nice to see the wet stuff Scottie. It really has tied everything together really well. Its a lovely subject to build.
Thanks Jim, glad you sticking with it.Hi Scottie
Nice looking paintjob.
Steven, Thanks mate They came out ok.Nice progress Scottie, white stripes are looking good :thumb2:
Steven
Thanks Steve, apart from a little bleed I'm happy.Nice work with the masking tape. Very straight and neat
HS ?I have started to add HS to the area I am going to mask so that if it does bleed/seep through I can gently remove it with water. HTH
That's a good idea.I have started to add HS to the area I am going to mask so that if it does bleed/seep through I can gently remove it with water. HTH
Andy, that sounds good to me I will bare that in mind next time.Looking good with some paint on Paul.
That's a good idea.
Another one is to spray a light coat of the "original" colour first. That should seal up any minute gaps in the tape, and if there is any bleed it'll be virtually invisible as it's bleeding over the top of itself (does that even make sense?). I haven't tried it on anything smaller than 1:1 scale lol, but ought to work.
Cheers John I'm not allowed matches.Oh don't faff about Steve just burn it off !.
Nice Paul, agree with the guys.
