Joe's 1/22 Artesania Latina San Francisco Cable Car
Hot off the press.
Glue dried overnight and this morning I added some filler in gaps and undesirable gaps.
Then lots of sanding took place, leaving a smooth, or 'homogeneous' surface, as the instructions refer to it.
Next stage of the build is to mask 80% of the thing off, and paint the reddish colour onto the outside of the cabin.
This is turning into something really nice Joe. Good part of San Francisco's history in miniature and from a different medium we're acustomed to here. Love it.
Thank you Richard. Lots more to go, I'm about a quarter of the way there.
Looks good Joe. I spent a few days in San Fran some years ago but didn't get to ride a streetcar - the queues were too long every time I went out, and a limo was only $2 to the waterfront.
Hi Joe, a very well thought out build, agree about the wooden sections, too easy to get the same types mixed up.
Such a mix of materials in the kit as well. Looking fwd to this build.
Masking, sanding...
Sanding, filling, priming, painting, sanding, filling, repeat until satisfied:
After two days I have a truly smooth surface with the blue band completed.
Next up is to mask the blue level off, and paint the reddish upper colour. I will report back when that red colour is on.
Cheers guys. First coat of red colour sprayed with the blue bottom masked off. The shade is as close as I could get to the reference photos. One more coat after 24 hours should do it.
That is looking down right "Spiffy" I suspect that red will deepen with the second coat.
Rick H.
Hi guys. Mega update again, I've been busy with work and building this cable car in my time.
Final coat of the red colour, deepened the shade as expected, and it will further deepen with a varnish coat.
Masking tape removed.
Then we move on to constructing the side windows. All primed.
Sprayed yellow
Using painted thin strips we make the white outline framing.
Sandwiching the clear acetate between the framed portions and the plain yellow pieces we get the completed side window sections
And then we move on to the four small windows for each end of the cabin
The small windows are varnished prior to sandwiching the acetate
The result
Prior to fitting all these windows I altered the order of things slightly and used strips of Tamiya masking tape cut into 1 mm widths to create the pin striping around the cabin. I had already glossed the cabin prior to this stage.
I had a bit of a nightmare with the very small curves on the sides, creating that old style carriage theme. Kept it simple, achieved something resembling the shapes I wanted. Not perfect but I'll accept it or I'll never get anything else done.
Then came attaching the horizontal bars to the end windows. First the brackets. As you might appreciate, these are extremely tiny and fiddly.
The horizontal bars are made from a length of wire provided. Unfortunately Artesania Latina saw fit to roll this up tightly and it made straightening the pieces out very difficult. Hence they are not precisely straight, but the effect is okay as you will see later on.
They are supposed to 'slot' right into the end cavities. Yeah right. A bit of sanding and persuasion and they go in. I found the actual best way to do this was to dismantle the window halves, put one half of the frame in, then attach the trimmed glazing in, then insert the other half. This is because if you force them in as a whole piece, the stress distorts the acetate glazing. No need to ask me how I know... A piece covering the gaps between the seats and the cabin walls was been inserted on each side.
The side window sections are inserted, and it's looking like a cabin now.
Then I placed the rubber matting down in the remaining deck areas per instructions. The white arrow is interesting, and appears on all the photos of actual cable cars. No idea what the reason is for that. On that note did you know the Powell Street Cable Cars are one-direction only. They must be turned on a turntable at the end of their routes. The California Cable Cars are multi-directional, the Grip Man simply walks to the other end of the cable car and drives back the other way.
That is a beautiful job and the taping really accents your work. Will you be varnishing the tape to permanently fix it in place? Yes Joe, I do know about the turntables and they are manually operated.....ask me how I know. Cheers, Rick H.
In the next installment...
The vertical poles within the cabin are attached to two horizontal overhead beams. each end of the white vertical poles have a brass cone hiding their attachments. The horizontal beams are measured and drilled with 2 mm cavities, in line with those pre-drilled on the floor and in the rubber surface.
The poles are now white
The poles are then mated with their brass ends, measured precisely so the ends protruding are the same. No one likes an uneven horizontal beam. The poles must be at 90 degrees for this to work, there is stuff all play in them and they are fragile...
This is what we get, one side completed. The horizontal beams are varnished afterwards.
There is a door of some sort that sits inside the frame of the exit leading tho the front of the car. I'm not sure where the door disappears to, but it's there in real life too. Maybe it is a concertina door? We must make the door up from these bits. The door panel is a laser cut piece, the brass brackets are the same pieces seen earlier, and the handles are from the same wire that made up the horizontal bars on the windows. I shaped the handles using the pliers shown in the photo. A bit of overkill perhaps, but it was effective. The scale is very small. The flat brass strips are cut from a strip provided.
I've taken to using Zap No-Drip Gel, it's superb stuff and I'm a fan now.
Varnished ready for insertion
Inserted, inner left side of the door at the front of the car cabin. Also attached is a varnished beam along the rear step of the cabin
Stunning piece of work Joe. Your attention to detail will pay huge dividends upon completion. Rick H.
