Hi all this will be my next build looks up to Tamiya normal standards but when I first assembled the engine block the fit was awful and I had to use clamps scarily tight to pull the engine halves together (luckily this area is hidden by the timing chain cases) also luckily the gearbox is a perfect fit so maybe the engine halves were warped for some reason and that will be the only problem I get. Which is also lucky as I intend to build the engine on a display stand to be put alongside the car (as if it's just been rebuilt ready to be put back in)The body moulding is awesome hardly any seams at all and the detail in the kit seems incredible
This is the same scale as the Bentley so is quite a large
